Hi all, just wanted to let you know that I've just removed the ac compressor from my 2004 v10 without removing the engine.
It wasn't even very hard... took about 2 hours but I think I could do it now in about 30 mins..
First I removed the Left side air filter box, 1 bolt and the 2 plastic pins oh, and clip out the little arm that holds the cover up.(I've got pics but they won't attach). Then the air pipe to the turbo, 1 spring clamp and 1 bolt on bracket to engine mount. Then the wire and 2 gas pipe on the compressor. Then 2 bolts (1 large 1 small) at the front of the engine that hold the heater hoses. The 2 small bolts on the tin bracket under the compressor and the bolt on the power steering pipe above the compressor. Then the three bolts holding the compressor on (13mm), you can't pull the bottom one out but you can undo it all the way. Then just pull it out! But the clutch only just fits through the hole in the engine mount so you gotta jiggle it arount but also hold pipes and wires out of the way. Once you get it loose then you gotta roll it over and twist it round as you lift it out...it is a very tight squeeze and the shaft on the front is quite long.
Don't know how I'm going to get the new one in but I guess it's just a reversal of that..
Btw, I've taped up the ends of my pipes to keep them clean and refitted all the bolts etc and have been able to drive without the compressor.
Also, my ac had no gas ( I had it checked) so removing the hoses was no problem. However, if you need to remove your compressor (to replace the rubber coupling) and your system still contains gas, then you should have it emptied by a trained ac mechanic.
I'll try to get my pics up later.
