The Raybestos are good but.....
I will put in my 2 cents for the quality of different combinations of brake components since I live on a hilly island and go through brakes more quickly than others may.
2006 : I performed a brake pad, rotor, sensor and hardware. I bought my components rom
www.pap-parts.com
Front pads: Hawk ceramic
Front Rotors: zimmerman plain faced
Rear pads: Hawk ceramic
rear rotors: zimmerman plain faced
The intial feel of the ceramic pads was what I thought was good, until I encounterded many instances where the brakes would feel like they were not holding or that there was some sort of debris between pad and the rotor.
they didn't create much dust.
2007 after not being satified with the performance of the Hawk ceramics, I contacted Geoff and convinced him to sell me a complete kit minus the rear rotors (a set of front rotors and a set of pads for the front and rear along with the hardware and sensor). I didn't have that many miles on the first set so I kept the rear zimmerman rotors
After installing the pads and new rotors from Alretta my car was a pleasure to drive NO squeeling brakes and pedicatible braking.... But I still
felt that the Alretta pads two short comings, they will always stop you but you have to apply pedal pressure, and the second was they did not last very long as I replaced them in early 2009.
2009 Hawk LTS
here is my current set up
Front Pads : Hawk LTS
Front rotors: Alretta supplied
Rear pads: Alrettas supplied
Rear rotors: Zimmeran
This current set has satisfactory braking for me, I did have to apply anti-Squeel to rear of the Hawks to stop them from sqeeling under light braking.
The hawks give better intial bite than the Alretta brakes and require less pedal pressure.
I do feel that if I had some hawk pad in the rear I might get even more balanced braking.
On my next brake replacement I will use both OEM pads and Rotors so I can get the impression of those as well.
So for now my rating would go
For enthusiat driving :
OEM pagid
Hawk LTS/HPS
For overall reasonable replacement:
Alretta premium touareg setup
Stay away from any ceramic compound pad on the touareg unless you are running slotted rotor.
