I know this has been a thought by many, but nothing was created. Now we can start a repository for all things VAG-COM for the 7P Touareg. Searching is always an option, but having a central location to find the most pertinent information would be helpful to everyone.
Going off of Noobytoogy’s Signature:
Seat Belt Warning Disable
*Remember to always write down or take a picture prior to making even then simplest changes.
Other Points of Reference:
Ross-Tech Wiki
T1 - Summary of VAG-COM tweaks for the Touareg (T1) 2004-2007
T2 - Summary of VAG-COM tweaks for the Touareg (T2) 2007.5-2009
VW Touareg models are as follows:
Generation 1: T1 is model 7LA & facelift T2 is model 7L6
Generation 2: T3 is model 7P5 & facelift T4 is model 7P6
Generation 3: T5 is model CR7 [Not available in "VW Atlas" North America!]
[Select]
[17-Instruments]
[Coding]
[Long Coding Helper]
One of the drop-downs for Byte 00, you should have options, one of which should be:
"Seat Belt Warning inactive"
Ross-Tech Wiki
