What brand oil do you use in your tregg?
21K views 35 replies 19 participants last post by  vwW12
i just bought mobil 1 extened life 10w30 15,000 mile last...i plan to change every 7000 miles or so. what are you all using.
For an oil and filter change for the V-8, add 8 quarts, drive it a bit and then let it drain down for 30 minutes or so and check the dip stick; then add just a bit until you are midway between the add and full marks. You don't want to fill to the top mark, as it will be over filled when the oil expands due to heat.
I would recommend that you use 0W-40 Mobil 1; the Mobil 30 weight oils don't meet VWs specs and don't perform well at high temperatures and high shear loading -- ie. they break down when you need the lubrication the most. It should be good for 7,500 miles unless your driving is severe service (a lot of stop and go, say New York City), then 5,000 miles is a better mark.
I can't find the file right now (I think its on my work computer), but I do actually have a copy of the VW 502.00 approval letter for LubroMoly Vollsynthese. The manufacturer is LiquiMoly and the current name of the oil is Synthoil High Tech (I have confirmed that only the name switched) which shows up on this list:
http://pics.tdiclub.com/data/529/Audi_Approved_Oil_Chart.pdf
I did painstaking research on the approval back when I found this product and was using it in my Jetta.
So, I'm not sure what list you are referencing - I'd be interested to see it in case I need to do some more research.
I do thank you for taking the time to look it up and post a warning. The last think I want is for VW to have any reason to hesitate about my warranty.
Just a suggestion here folks.... stick with the VW approved oils because if you have an engine problem ---- watch how fast VW denies a warranty claim. Then there will be a person bitching and moaning about how VW sucks and blah, blah, blah... and there won't be any sympathy from me.
Sorry but I disagree. First of all the Federally mandated Magnuson-Moss act states that a manufacturer may not require the use of a specific brand of aftermarket product unless it is provided free of charge.
The amsoil for example meets or exceeds the specs of VW. They just do not have the desire to be on a approved list. I asked them. Besides that VW will have to prove that failure was caused by the oil.
Just googled a bit and for those who want to know exactly can read it here.
Amsoil and Your Car's Warranty, The Law
Here is the info on the oil I use. Show me an oil with better results.
Product Description
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFL) is specially formulated for the lubrication needs of modern European gasoline and diesel cars and light trucks. Formulated with advanced AMSOIL synthetic base stocks, premium additives and a 5W-40 viscosity rating, AMSOIL AFL is the preferred oil for virtually all European automobiles, especially turbo charged models. It is one of the only oils in North America to be recommended for the latest specifications of all three major European automakers - Volkswagen (Audi), BMW and Mercedes-Benz and the latest North American API specification. AMSOIL AFL is highly versatile for multiple applications.
AMSOIL, the leader in automotive synthetic lubrication, produced the world's first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
Maximum Engine Protection
AMSOIL 100% Synthetic European Car Formula contains high quality anti-wear additives and surpasses the tough ACEA oil specifications for high temperature/high shear viscosity. It provides outstanding protection in high RPM, hot running engines and delivers dependable long-term performance for the extended drain intervals set by European automakers.
Superior Engine Cleanliness
The excellent oxidation stability, heat resistance and detergency properties of AMSOIL Synthetic European Car Formula keep engines clean. It is specially designed to prevent sludge and varnish deposits for reduced oil consumption, extended engine life and maximum overall performance.
Minimizes Exhaust Emissions
AMSOIL European Car Formula is designed for newer vehicle emission control systems. It meets current industry and vehicle manufacturer requirements for long life protection of gasoline vehicle catalytic converters and diesel particulate filters (DPF).
All Season Performance
The broad 5W-40 viscosity rating, low volatility (burn-off) and wax free nature of AMSOIL Synthetic European Car Formula make it excellent for hot and cold temperatures. Engine wear is reduced, oil thickening is controlled and vehicles start easier in cold temperatures.
APPLICATION
AMSOIL 100% Synthetic European Car Formula is formulated to surpass the most demanding European specifications. It is recommended for European and North American gasoline or diesel vehicles requiring any of the following worldwide specifications:
  • <LI class=style3>API SM/CF <LI class=style3>ACEA C3-04 <LI class=style3>ACEA A3/B3-04 <LI class=style3>ACEA A3/B4-04 <LI class=style3>ACEA C3 <LI class=style3>BMW LL-04 <LI class=style3>Mercedes Benz 229.31, 229.51 <LI class=style3>Porsche <LI class=style3>Saab <LI class=style3>Volvo <LI class=style3>Volkswagen 502.00, 505.00, 505.01
  • DaimlerChrysler MS-10725
Service Life
Recommended for the extended drain intervals established by the vehicle manufacturer or extend based on oil analysis. Change oil filter at time of oil change.
Mixing AMSOIL
AMSOIL AFL is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
Health & Safety
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). An MSDS is available upon request at 715-392-7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don't pollute. Return used oil to collection centers.​
TYPICAL TECHNICAL PROPERTIES
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
13.7
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
79.7
Viscosity Index (ASTM D-2270)
177
Viscosity CCS, cP @ °C (ASTM D-5293)
5121 (-30)
Flash Point °C (°F) (ASTM D-92)
230 (446)
Fire Point °C (°F) (ASTM D-92)
246 (474)
Pour Point °C (°F) (ASTM D-97)
-42 (-44)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
8.7
Four Ball Wear Test (ASTM D-4172B @ 40 kg, 75°C, 1200 rpm, 1 hr), Scar, mm
0.44
Total Base Number
8.0
HTHS (cP) (ASTM D-4683)
3.7
nltomba,
I found corresponding numbers for the LiquiMoly oil I use. I don't know exactly what they mean but to me this looks comparable to the Amsoil product specs you posted. I'd be really interested to know your thoughts on how the two products compare - especially in light on the great reputation that Amsoil has.
Synthoil High Tech
SAE 5W-40
DESCRIPTION Synthoil High Tech SAE 5W-40 is a fully synthetic, high-performance, low-friction
engine oil designed for year-round use in passenger motor vehicle engines.
Optimum high-performance for multi-valve and turbocharged engines. The
synthetic base oils and high-quality additive components satisfy and greatly
exceed the requirements of the most state-of-the-art engine designs.
PROPERTIES - long service life for the engine due to very high level of protection against wear
- miscible and compatible with commercially-available engine oils.
- rapid oil delivery at low temperatures
- very high lubrication reliability at high and low temperatures
- very high shear and ageing stability
- outstanding engine cleanliness
- smooth engine running
- saves petrol and reduces pollutant emission
- optimum oil pressure at all engine speeds
- tested with catalytic converters and proven performance with turbochargers
- extremely low evaporation losses
Specifications / Approvals:
API SM/CF
ACEA A3-04/B4-04
LIQUI MOLY recommends this product for vehicles for which the following
specifications are required
MB 229.3
BMW Longlife-98
VW 502 00/505 00
Porsche
TECHNICAL
DATA Viscosity class : 5W-40
Density at 15 °C : 0.850 g/cm³
Viscosity at 40 °C : 86 mm²/s
Viscosity at 100 °C : 14.1 mm²/s
Viscosity index : 170
Flash point : 222 °C
Pour point : -45 °C
ASTM colour : 3,5
Ash, sulphate : 1.2 g/100 g
Kind of hard to tell, since I do not know the other oil. I just know that I have always been very happy with amsoil. I have about 300000miles experience with it so far.
Abou warranty stuff:
Most car owners go to places like walmart and jiffy lube and I have never heart of problems due to different brands of oil.
Yes if you need to use a 0W20 oil and put 20W50 in it and get problems that is a different story, but as long as it meets specs you are ok.
Besides that amsoil stands behind its product so VW in a lawsuit will have to fight amsoil, not me.
There is no better choice than Castrol Syntec 0w30. This is the "Made in Germany" oil that is labeled as "European Formula". It's hard to find (Most Auto Zones in the US carry it, and Walmart in Canada for some reason), usually 6.99 a quart. The "Bob is the Oil Guy" web site is probably the most hardcore oil forum on the web and they love it. Check out this thread: FAQ - GC ( German Castrol ) - Bob Is The Oil Guy
Whatever you do, make sure it meets the appropriate VW spec for your particular car.
Enjoy!
T-Man
Engine oils which currently meet VW Oil Quality Standard VW 502 00
Please note: Not all oils listed may be available in North America
Audi/VW original parts Part number ZVW 352 540 S SAE 5W-40
Audi/VW original parts Part number G 052 167 A2 SAE 5W-40
Addinol Addinol Extra Power MV 0538 LE SAE 5W-30
Addinol Addinol Super light MV0546 SAE 5W-40
Addinol Addinol Super power MV 0537 SAE 5W-30
Addinol High Star SAE 5W-40
Adnoc ADNOC Image SAE 5W-30
Agip Agip Extra HTS SAE 5W-40
Agip Agip Sint Evolution SAE 5W-40
Agip Agip Synthetic PC SAE 5W-40
Agip Agip Tecsint SAE 5W-30
Agip Agip Tecsint SL SAE 5W-40
AnYe Lubricating Oil AnYe 1 SAE 5W-40
Aral Aral HighTronic SAE 5W-40
Aral Aral SuperSynth SAE 0W-40
Aral Aral SuperTronic SAE 0W-40
Aral Aral Tronic 431 SAE 5W-40
Bardahl Bardahl XTC 100% Synthetic Motor Oil SAE 5W-40
Beijing Tongyi Petroleum Xin Gai Nian SAE 5W-40
BP BP Euro Germany SAE 5W-40
BP BP Euro Plus SAE 5W-40
BP BP Euro Spirit SAE 5W-40
BP BP Visco 5000 SAE 5W-40
BP BP Visco 7000 SAE 0W-40
BP BP Visco 7000 Sport SAE 5W-40
BP BP Visco 7000 TD SAE 5W-40
BP BP Visco 7000 TD Sport SAE 5W-40
BP BP Visco Special V SAE 5W-40
BP BP Visco Sport SAE 0W-40
BP Meister-Öl Leichtlauf-Motorenöl SAE 5W-40
Bucher AG Motorex Xperience FS-X SAE 5W-40
Bucher AG Select SP-X SAE 5W-40
Bucher AG Xperience FS-X SAE 0W-40
Carat Carat ad-Synt-Oil SAE 5W-40
Carl Bechem Hessol ADT Plus SAE 5W-40
Carl Bechem Staroil Synergie Alpha SAE 5W-40
Cartechnic Cartechnic Motorenöl SAE 5W-40
Castrol Adamol Multitop PDI SAE 5W-40
Castrol Castrol 505 01 SAE 5W-40
Castrol Castrol Edge SAE 0W-40
Castrol Castrol Formula RS Road and Track SAE 5W-40
Castrol Castrol GTD 505 01 Top Up SAE 5W-40
Castrol Castrol GTD Direct Injection SAE 5W-40
Castrol Castrol GTX 5 SAE 5W-40
Castrol Castrol GTX 7 Dynatec SAE 5W-40
Castrol Castrol GTX 7 Dynatec Neu SAE 5W-40
Castrol Castrol Performance SAE 5W-40
Castrol Castrol TXT 505 01 SAE 5W-40
Castrol Castrol TXT Softec SAE 5W-40
Castrol Castrol TXT Softec Plus SL SAE 5W-30
Castrol Castro Edge SAE 5W-40
Castrol Castrol Syntec SAE 5W-40
Cepsa Cepsa Star Mega Synthetic SAE 5W-40
Cepsa Cepsa Star TDI Synt SAE 5W-40
Chevron Havoline Ultra S SAE 5W-40
Chevron Havoline Ultra S SAE 5W-30
Coparts Carl Motorenöl Power SAE 5W-40
Cyclon Hellas Cyclon F1 Racing SAE 5W-40
De Oliebron Tor Hypersynth SAE 5W-40
Dongying Xinyi Xin Yi 1 SAE 5W-40
Duckhams Duckhams Q Fully Synthetic SAE 5W-40
Duckhams Duckhams QS SAE 5W-40
Duckhams Duckhams QS Premium MO SAE 5W-40
Elf Elf Excellium DID SAE 5W-40
Elf Elf Excellium LDX SAE 5W-40
Esso Esso Megatron SAE 5W-40
Esso Esso Ultron SAE 5W-40
Esso Esso Ultron SL SAE 5W-40
Esso Motor Oil Plus SAE 5W-40
Eurol Eurol Super Lite 5W-40 SL/CF SAE 5W-40
Feu Vert Feu Vert 100% Synthese SAE 5W-40
FL Selenia Pulsar S.D. SAE 5W-40
FL Selenia Selenia WR SAE 5W-40
Fuchs Fuchs TITAN Supersyn SAE 5W-30
Fuchs Fuchs TITAN Supersyn SAE 5W-40
Fuchs TITAN Formel MC SAE 5W-40
Galp energia Galp Energy Plus SAE 5W-40
Galp energia Galp Energy SP SAE 5W-40
Galp energia Galp Energy Ultra LS SAE 5W-40
Galp energia Galp Formula 1 Plus SAE 5W-40
Galp energia Galp Formula 505 SAE 5W-40
Galp energia Galp Formula TD Plus SAE 5W-40
Galp energia Galp Formula XLD SAE 5W-40
Gamaparts Gamaparts Gold Synt SAE 5W-40
Ginouves York 848 SAE 5W-40
Gulf Gulf Formula GX SAE 5W-30
Gulf Oil Gulf Formula G SAE 5W-30
Gulf Oil Gulf Formula G SAE 5W-40
Huiles Labo Labo Carat SAE 5W-40
Igol Igol Symbol Ceramic SAE 5W-40
Igol Process Compact P SAE 5W-30
INA INA Futura MB SAE 5W-30
Iranol Iranol 30,000 SAE 5W-40
Kendall Motor Oil Kendall GT-1 Full Synthetic Motor Oil SAE 5W-40
Kuttenkeuler Motorenöl S-Tronic SAE 5W-40
Liqui Moly Liqui Moly Leichtlauf HC 7 SAE 5W-40
Liqui Moly Liqui Moly Longtime High Tech SAE 5W-30
Liqui Moly Liqui Moly Profi Synthoil SAE 5W-40
Liqui Moly Liqui Moly Synthoil High Tech SAE 5W-40
Liqui Moly Liqui Moly TopTec 4100 SAE 5W-40
Longpan Petrochemical Sonic 9000 SAE 5W-40
Lotos Lotos Dynamic SAE 0W-40
Lotos Lotos Economic SAE 5W-30
Lotos Lotos Syntetic SL/SJ/CF/CD SAE 5W-40
Lotos Lotos Traffic SAE 5W-40
Lukoil Lukoil-Synthetic SAE 5W-40
Meguin EMARAT Power Synth SAE 5W-40
Meguin megol Motorenoel New Generation SAE 5W-30
Meguin megol Motorenoel Super Leichtlauf SAE 5W-40
Meguin Motorenoel Low Emission SAE 5W-40
Meguin Motorenoel Ultra Performance Longlife SAE 5W-40
Meguin Olympia Pro-Tech Fully Synthetic Engine Oil SAE 5W-40
Mobil Mobil Special X SAE 5W-40
Mobil Mobil Syst S SAE 5W-40
Mobil Mobil Syst S ESP SAE 5W-30
Mobil Mobil 1 SAE 0W-40
Mobil Mobil 1 SAE 5W-40
MOL MOL Dynamic Star SAE 5W-40
MOL MOL Dynamic Synt SAE 5W-40
Motul Motul 8100 X-cess SAE 5W-40
Motul Motul 8100 X-clean SAE 5W-40
Motul Motul H-Tech Multi Standard SAE 5W-40
Motul Motul Specific 505 01 SAE 5W-40
Motul Motul Synergie SAE 5W-40
MRD Motor Gold Supertec SAE 5W-40
Nocc Valar Gema XLL 053 SAE 5W-30
Northland Synergy Synthetic EuroSyn SAE 5W-40
Oel-Brack Midland Avanza SAE 5W-40
Oel-Brack Midland Synqron SAE 5W-30
Oel-Brack Midland Synqron SAE 5W-40
Oest Oest ETA Synthetik SAE 5W-40
Oktanoil Mega Full SAE 5W-40
Ă–lwerke Julius Schindler Econo Veritas XL-HC SAE 5W-40
Ă–lwerke Julius Schindler OJS Econo-Veritas XL-HC SAE 5W-40
Ă–lwerke Julius Schindler OJS Engine Oil SAE 5W-40
Ölwerke Julius Schindler OJS Meister-Öl Premium-Motorenöl SAE 0W-40
Ă–lwerke Julius Schindler OJS Veritas Syntolube SAE 0W-40
OMV OMV full syn plus SAE 5W-30
Orlen Oil Orlen Platinum Vollsynthese SAE 0W-40
Orlen Oil Plantinum Synthetic SM/SL/CF SAE 5W-40
Orlen Oil PLATINUM MAXENERGY EURO4 SAE 5W-30
Panolin Panolin Indy SV SAE 5W-40
Paramo Mogul Racing Pro SAE 5W-40
Pennzoil Pennzoil European Formula Ultra SAE 5W-30
Pennzoil Pennzoil Platinum European Formula SAE 5W-40
Pennzoil Pennzoil Platinum European Formula Ultra SAE 5W-30
Pennzoil Pennzoil Synthetic European Formula SAE 5W-40
Pennzoil Pennzoil Synthetic European Formula Ultra SAE 5W-30
Pentosin Motorenoel Pento High Performance SAE 5W-40
Petro China Kunlun HTPC SAE 5W-40
Petro China KUNLUN Tianrun SAE 5W-40
Petrobras Lubrax Sintético SAE 5W-40
Petrol Ofisi PO Ultra SAE 5W-40
Petronas Petronas Syntium 3000 SAE 5W-40
Petronas Petronas Syntium 3000 LL SAE 5W-30
Petronas Petronas Syntium 3000 S SAE 5W-40
Petronas Petronas Syntium 5000 FS SAE 0W-40
Poweroil High-Tech-Schmierstoffe HD 5W-40 SL CF Topsynth SAE 5W-40
Prista Oil Prista Ultra SAE 5W-40
Profi-Tech Profi-Car Synth Tech XT SAE 5W-40
Protech Meister-Öl-Leichtlauföl SAE 5W-40
Quaker State Q European Engine SAE 5W-40
Quaker State Q European Engine Ultra SAE 5W-30
Quaker State Quaker State European Formula Ultra SAE 5W-30
Quaker State Quaker State Full Synthetic European Formula SAE 5W-40
Quaker State Quaker State Full synthetic European Formula Ultra SAE 5W-30
Rafinerija Modrica Optima Magnum Plus SAE 0W-40
Ratio Ratio Super Leichtlauf Motorenöl SAE 5W-40
Ravensberger Schmierstoffvertrieb Ravenol Hydrocrack Synth. HCS SAE 5W-40
Ravensberger Schmierstoffvertrieb Ravenol VSI SAE 5W-40
Repsol Repsol Elaion Full Performance SAE 5W-40
Repsol Repsol Elaion Full Performance SM SAE 5W-40
Repsol Repsol Elite Cosmos SAE 0W-40
Repsol Repsol Elite Evolution SAE 5W-40
Rowe Hightec Synth RS 5W-40 i SAE 5W-40
Rowe Hightec Synt-HC 5W-40 i SAE 5W-40
Rowe Rowe Synt PD SAE 5W-40
SCT Mannol Extreme SAE 5W-40
Seventy-Six Lubricants 76 Pure Synthetic Motor Oil SAE 5W-40
Shanghai Tempo Tempo 8000-1A SAE 5W-40
Shell Formula Shell Ultra AB SAE 5W-30
Shell Sehll Helix Ultra AM SAE 5W-40
Shell Shell Helix Plus SAE 5W-30
Shell Shell Helix Plus SAE 5W-40
Shell Shell Helix Plus S SAE 5W-30
Shell Shell Helix Plus S SAE 5W-40
Shell Shell Helix Premium SAE 5W-40
Shell Shell Helix Ultra SAE 5W-40
Shell Shell Helix Ultra SAE 5W-30
Shell Shell Helix Ultra AB SAE 5W-30
Shell Shell Helix Ultra AL SAE 5W-30
Shell Shell SL 0914 SAE 5W-40
Sinopec Polar Star SAE 5W-40
Sinopec Polar Star II SAE 5W-40
SK Corporation ZIC XQ SAE 5W-40
Slovnaft Madit Ultra SAE 5W-30
Smessindo Liqtro Enduro Ultra SAE 5W-40
SRS Schmierstoff Vertrieb Wintershall Primalub topsynth SAE 5W-40
SRS Schmierstoff Vertrieb Wintershall VIVA 1 Longlife SAE 5W-30
SRS Schmierstoff Vertrieb Wintershall ViVA 1 topsynth SAE 5W-40
SRS Schmierstoff Vertrieb Wintershall ViVA 1 topsynth alpha SAE 5W-30
SRS Schmierstoff Vertrieb Wintershall ViVA 1 topsynth alpha LA SAE 5W-30
Startol Synt-XL SAE 5W-40
Statoil Statoil GT S SAE 5W-40
Statoil Statoil LazerWay SAE 5W-40
Statoil Statoil LazerWay C SAE 5W-40
Statoil Statoil Pro Synthetic SAE 5W-40
SWD Concep-Tech HDC SAE 5W-40
SWD swd Primus HDC SAE 5W-40
Texaco Havoline Ultra SAE 5W-40
Texaco Texaco Havoline Ultra BM SAE 5W-30
TNK Lubricant LLC TNK Ultra SAE 5W-40
Top Oil Top Evolution SAE 5W-40
Unicorn Unicorn Ultra Synt SAE 5W-40
Unil Opal Opaljet 24S SAE 5W-40
Valvoline Valvoline DuraBlend MXL SAE 5W-40
Valvoline Valvoline SynPower SAE 5W-30
Valvoline Valvoline SynPower MXL SAE 5W-30
VAPS VAPSOIL 502 00 SAE 5W-40
VAPS VAPSOIL 505 01 SAE 5W-40
Volkswagen Mexico Audi, Seat, VW Aceite para Motor a Gasoline
VW 502 00 100% Sintético
SAE 5W-40
Volkswagen Original Teile ® Volkswagen Special plus SAE 5W-40
Westfalen AG Westfalen Gigatron SAE 0W-40
Wolf Wolf Masterlube Synflow DC SAE 5W-40
WĂĽrth Triathlon Synthetic SAE 5W-40
Yacco Yacco VX 1000 SAE 5W-40
Yacco Yacco VX 600 SAE 5W-40
YPF Elaion Plus VWS SAE 5W-40
YPF Elaion Sintetico VWS SAE 5W-40
YPF YPF Elaion Full Performance SAE 5W-40
YPF YPF Elaion Full Performance SM SAE 5W-40
Zeller+Gmelin Divinol Syntholight SAE 5W-40
A long list. I don't think we can claim that VW is trying to make us use only dealer bought oil though...
SAE 5W-40
EXCELLENT POST!!! thanks for the info!!!!!!
#33 ·
Yeah, the drain plugs are terrible. Nearly crapped myself when my drain pan almost overflowed due to the gush of oil!!! Holy smokes! Hotta drill extra purge holds in my drainpan. Love the Mobil 1!!!
