Transmission is done for?
3.3K views 13 replies 7 participants last post by  Fonzi
I was starting to think it might be the valve chest, but I'm not completely sure.
Just today, I would drive normally, starts off in 1st, gets about to 10/15 mph then it just loses power.
It's not just in 1st, it's all gears. Driving 70 in 6th and just normally on the gas, I could floor it and about 2 seconds later it finally gets power.
Passed a stop sign later on, car dies halfway through. No warning lights or anything.
I can't drive the car like this, if I pull out and someone is going 60 and comes up on my and my car dies, I'm f*cked.
If its the transmission, I'm surely done for. Any ideas?
Does the engine seem to be running properly?
regards
Drag
VCDS for fault codes and check ATF level as above.
I have the same thing on my treg but it's just in 1st and 2nd gear.
When accelerating and the gearbox switches to next gear, the car suddenly drops power for a second, then revs again and finally switches to next gear so gear changes takes more than 3 seconds with lots of judder...
I learned to live with it, but my car never died yet.
I did a diff replacement with lower gear ratios and it wasn't an improvement, it just get worse instead. Did a transmission fluid change 2 weeks ago, no difference.
I'm think to do an update of my transmission ECU.
Someday i'll make a video from it.
