I noticed an oil drip on my driveway from my 2006 VW Touareg 5.0L V10 TDI so i removed the protective plastic shield below the vehicle. I noticed the fluid was red which indicated to me that it was transmission fluid. I wiped everything clean & tightened the bolts on the transmission oil pan. After having the vehicle sit for a few hours there was fluid collecting at the threaded hole of the transmission. Is there a plug missing from the threaded hole?
The first picture shows the fluid leaking out of the threaded hole. The second photo shows a close up of the hole.
