Have only put about 200kms on the MY15 V8 TDI that I got recently and interestingly noted that it hardly ever uses the first gear. Almost always it starts off in 2nd and upshifts quite smoothly & successively to the 8th once the needle is over 100.
I had driven the 7P, only the V8 several times before but never had my eyes on the gear shift numbers on the MFI.
Is this the same for every other 7P model whether V6 or V8? Can anyone share their experience pls.
Its appears the 1st is quite low and would help with some offroad work
Maybe soon in future there will be no low range in most 4wds....with upto 9 gears available in some models it would give some decent low range ratios making twin boxes redundant.
have a 10 speed box and a diff lock, that would cover most needs.....
