The VR6 I'm getting has 3 4Wd settings, 4Hi, 4Lo, & center diff lock. in center diff lock, can that be used at any speed, or does it only lock front to rear in low?
Winter only, I run the Hakka 5 SUVs which are winter only tire...I run Yokohama Parada 20"ers in spring/summer/fall.Hey nikm, How do you like the Nokians? Do you just run them during the Winter, or year around?
Cya
They all have the locking center differential. If you have the optional locking rear diff, you will have an additional position at the 6 o' clock position of the transfer case mode switch. You'll have High, Low, Center, and Rear in that order, going clockwise around the switch. No rear lock means no options pas the 4 o'clock area on the switch.How can I tell if my Treg has a locking Diff?
Thanks
Thanks nickm for the info.
Deep down I know that I will probably have to get two sets of tires, but I was just hopeful that maybe I could have squeezed by with one set.
Oh well.
Cya
