Our Gibb River Adventure
12K views 40 replies 13 participants last post by  Coight57
only 3 1/2 weeks till we commence our epic adventure to the Kimberley. today I got some new tyres fitted.
went with Cooper AT3 the heavy duty LT version. 265/60R18 bought 6 new tyres. hopefully they do the job.
#4 · (Edited)
Good choice both in tyre and size, I believe that the LT's is the only way to go when heavily loaded and doing long distances on some very ordinary inland roads.
They will do the job for you!
Tony
Good on you Ragman! And all the best on the Gibb, its an awesome experience and part of Australia!
How are the tyres on road, noise and in wet?
Btw we had a great run across Gibb but got two flats in the last 70km section coming up to el questro
the tyres are quiet on the road Singh, but they are brand new, as the tread is not extreme I'm hoping the noise doesn't get intrusive.
First rains for a while are expected tomorrow or Saturday so I'll find out then what the wet grip is like.
Were your flats side wall stacking or punctures? what tyres were you running?
Hi mate,
One was sidewall and the other one right in the middle
I blew the sidewall out of a Goodyear Silent Armor (kevlar) on the Gibb. 265/60R18
My fault - travelling (with camper trailer) too fast, which can be a problem with a Treg, especially a V10.
Nev at Imintji Roadhouse (sold tyres) said for dirt roads, 80kph and 32psi max. Never had a problem after that.
May be worth keeping in mind. Dub
Interested to know how your tyres go. We ended up with one puncture after none on the Plenty, none on the Tanami and none on the Gibb and Mitchell Falls road. Towards the end of the dirt on the Savannah Way near Hells Gate.... small slice on the side wall which I had repaired as an emergency spare. Finished the dirt now (2500+ kms) with black top all the way home. Some is luck, like Dubby I ran mine around 30-32 rear and 26-28 front.... on the Mitchell Falls road we went down to 25/23 psi which worked well for better comfort and puncture proofing.
Avoiding rocks and keeping focused on where you're driving obviously helps a great deal. Trying to do that for hours upon hours is difficult, and some roads are very rocky. Mine are Michelin Latitude Cross (not LT)... and we saw many LT tyres punctured and destroyed out along the Gibb and Mitchell Falls road in particular. But, light truck has typically another ply than non-LT in the side wall (some more), so there is better protection with light truck. Best protection in my opinion is lower pressure and slower speed... and focused driving to minimise potential dramas. Btw, I agree light truck version tyres are best for these type of roads.
See below.... light truck all-terrain Bridgestone. But this guy didn't know reducing tyre pressure helped? He also said with modern cars you can't feel when you get a flat?
Cheers Paul.
Agreed Paulm57, driving technique is probably the most important factor. I hear plenty of stories about people ripping past at 90 - 100 kph only to be found up the road with tyre or suspension damage.
We will be taking it very easy.
do you mean the roof rack wigdog? its a Ironman the dealer in Osborne park Totally 4x4 were really helpful with fitting bolts etc.
its a steel flat rack for a prado but I sometimes wish I'd lashed out and got the ali unit which is a bit lighter.
Gibb river road
Ragman, have a safe trip and enjoy.
do love the colour of your car ( same as mine) wonder if it will be the same colour when you get back
:wink2:
Cheers Brent
Nice job Rman with the fitting the cargo barrier and drawer system.
I looked at doing the same thing but was put off by the weight of the drawer system (I think from memory it was over 100kgs) as I did not want to exceed my GVM.
So before doing anything I decided to check my tare and consequently my payload by obtaining an actual weighbridge reading and comparing that to the GVM of my V6Tdi, (2945kgs).
Tare weight was 2660kgs which included myself, full tank of fuel, full size spare, tool box, compressor, fridge slide (no fridge), 2nd battery, tow hitch plus other minor bits and pieces which leaves me a payload balance of only 285kgs for passenger, food, bags, water and other gear and if towing anything, the BALL WEIGHT of the trailer needs to be factored in.
As you can see from these figures you haven't got a great deal of payload to work with, you may also find that with your V10 you may actually have a smaller payload due to the extra weight of your engine.
I suggest you may want to do similar checks just to make sure you don't inadvertently exceed your GVM!
TonyB
I took the rig over a weigh bridge last year with a similar setup and loaded up it was under GVM. I have not weighed the drawers but no way are they 100kg I guess 30 or 40kg and removing the rear seats saves 20 or 30kg. I will check it on the local weigh bridge before we go and confirm the weights.
Actually for this trip we have managed to prune a lot of unnecessary stuff in order to reduce the weight of tug and trailer.
Pump the tyres up till they look good, and nobody will ever notice !! TIC
#22 · (Edited)
The dimensions of the drawers are as follows:
Dimensions
DRAW SIZE: 900mm (L) x 1000mm (W) x 270mm (H)
DRAW TANK SIZE: 790mm (L) x 430mm (W) x 190mm (H) (2 tank/set)
TOP SLIDE: 900mm (L) x 495mm (W)
NET WEIGHT: 71kgs
DRAW EXTENDS OUT: 560mm
FRIDGE SLIDE EXTENDS OUT: 545mm
so...somewhere in between - 71kg
owns 2015 Volkswagen Touareg R Line
Reactions: Ragman
an old engineer I worked with told how if they wanted to know the weight of something he would ask everybody in the workshop what they thought it weighed.
then he would average the guesses and invariably the average would be very close to the true weight...
So what do you think the rear seats weigh?
I have not found the weights I measured last year. but with the trailer on ball the GVM was just under the 3100kg and I'm pretty sure the trailer was around 1750kg.
I took it over the Balcatta weigh bridge first I did a total and then just the trailer wheels. I have a tow ball scale at home which gave about 240kg.
We have managed to jettison a lot of unnecessary stuff this year, but that will be negated by the extra spare on the roof rack.
Probably drive through the Weigh bridge on the way out of town on Friday.
Overloading is becoming a big issue in some states I believe with road blocks to check caravans etc.
(might have to get the wife to hop out of the car if we get checked LOL)
So you don't each keep a key on you...?
There is a way to get into the T1 and T2 to pull the manual tailgate release but it's not for open discussion and, whilst it's not cheap either, it is a lot less than $900!
Somehow managed to lock the keys in the back of the car.
I have had a key cut that will only open the drivers door specifically for the reason that if you only open the rear door (boot) with the remote and leave the key in the Treg, as soon as you shut the rear door the Treg will lock and you will be locked out.
The spare is carried in a magnetic holder oon the outside of the vehicle.
If we are away on an extended trip, the second remote is carried in our luggage.
Yea no. The spare key is not in good shape, so we only use the one key usually. In hindsight we should have brought it any way but it probably would have been in the wife's bag which was in the back seat. Need to get a hidy hole to conceal a spare key.
#37 ·
Who said you can't repair sidewalls!?
