X2 , don't forget, the T3 uses a torsen center diff, which is a mechanical, torque sensing, locking diff, as opposed to the older electrically operated, disc clutched, center diffs ( locked when actuated but open when not). It is missing the epicyclic reduction gearing, but the 8 speed gearbox's first is plenty low for all but the most extreme conditions. The offroad mode optimizes the ESP/ASR/EDL and ABS interventions with respect to traction and braking performance on loose surfaces offroad. Greater wheel slip values are allowed until one of the control systems are actuated. The EDL function ( which by high frequency single wheel braking transfers power away from the slipping wheel) is activated at low differences in wheel speed. Very similar result in overall traction to a conventional locker.
IMO, Comparing it to my Landcruiser, it is probably more capable and much easier to drive 95% of the time in low traction situations
Don't forget, a huge percent of a vehicles capability offroad rests in the skill and experience of the driver!!
All that said, I would like a set of decent skid pans for the T3... ;-)
