201 - 220 of 232 Posts
make sure your canbus is set correctly.
go to phone dialer and dial #*98723 and press call/dial
It will look like this
Make sure CANBUS is set to your car.
Discussion starter · #204 ·
So I've had my ANS710 for nine months and today I get a an application error message "application Platform.exe has experienced a serious error and must close", but then nothing happens. I can turn it on and off, but all I get is the error message and no sound.
Anybody have a clue?
Cstrava,
I believe it can. All you have to do is purchase the lightning adapter. I bought the s150 (Andriod) radio for my 05 TREG. I was able to connect 2 ways with my iphone 5s.. Bluetooth and the wired connector that comes with the radio...However, I had to buy an adapter for my iphone and both ways worked great.. I would confirm with Allen on this but im pretty it is since i've seen plenty of posts regarding your same question.
I have one installed in my treg.
The sound quality is what I would call "ok". It's not as good as it was, I had the factory digital amp fyi.
This is due to the fact that now we have only 4 speakers vs the 9 or more speakers they came with.
Allen and I have been talking about a passive crossover that could be installed back in the amps original location. This would give us all our speakers (minus the center channel) back and our sound back.
Another option would be to install some RCA's from the new unit back to the amp them removing the RCA ends and bare the wires and hook them up at the OE amps input locations.
This quite honestly sounds to me to be the best option.
I've not had a chance to try this yet but hope to this next week. I will report back after I try this also.
Side note. Allen has been completely amazing to work with. He truly wants to make sure I'm taken care of. I highly recommend him if your in the market.
Hi Zukgod, have you had a chance to look into this? I am pleased with everything about this deck except the 4 speakers. Where you able to get all 9 going again? TIA.
Crap no...
I've not even been driving the Treg the last month or so with this moving happening.
Honestly though I see no reason this will not work.
The factory amp is using only 4 inputs and braking that out to the 9 speakers.. Using RCA's with the ends removed and tapped into the amps input this should work fine.
Heck I remember back in the day I would take my Walkman (dating myself here) and strip the headphone wires, hook them to the input on my cars amp and ROCK OUT!!
If I have time I'll do my best to see this through this week.
