Hey guys. We have an 04 V6 with the standard headlights (I believe H7 and H9 bulbs). Last week my drivers side DRL/Headlight stopped working. I figured it was the bulb. I pulled it apart and the bulb was fine. Checked the fuse and it was also fine.
So I decided to try the housing on the other side and sure enough, everything works as it should. When I put the passenger side housing on the driver side, it has the same problem.
I checked the voltage and it seems that the pin leading to the running (parking) lights is putting out 14.6 volts give or take. The pin for the headlight/DRL is at 13.3 but what is strange is it isn't showing it as positive voltage. Typically it will light up positive or negative and show the current. On the other side it shows 14.6 and the positive led lights up. Here it is almost as if it is grounded out though I have never seen this tester not identify the line being tested as either positive or negative??? So I am puzzled.
So my question would be how likely would it be that the headlight switch went bad, or is there something else I should be looking for like a control module, etc? Or any other ideas? I figue with the basic lights that there wouldn't be anything fancy but who knows on this thing.
Also, if someone has a Bentleys or other manual outlining the electrical system I would love an email.
Finally, will vag-com software be able to help me with this? I have yet to purchase the cable or software, any advice on this would also be appreciated.
Thanks allot!
Thanks allot!
