Just want to ask a quick question to which I hope someone who has gone down this path before may have the answer to. the front diff on the old girl has decided to start whining and id like to overhaul it before further damage ensues. From what I have read there seems to be a discrepancy for the carrier bearings. Some say that the bearing and race that are installed is a Timken KLM 503349 and KLM 503310 combo and to replace it with Timkin LM503349 and 503310 combo. However after some research on those part numbers one thing stood out. Both bearings have the same inside and outside diameter but where the difference lies is the thickness. The KLM part numbered bearing is 20mm thick and the LM part numbered bearing is 18mm thick. Does anyone have a picture of the number on the originally installed bearing and race?
Also could anyone supply a part number for the pinion bearing and crush sleeve? many thanks in advance, and yes I will update and post pics of the work moving forward from here.
