Hi everyone and thank you in advance, this is a great firum and has helped me with any issue ive had so far. However, I cannot find in the search the exact same problem ive been having this past couple of days.
It started yesterday morning, temp was around 3*c so not extremly cold but the coldest morning of the year so far (and the coldest since i bought the treg 4 months ago). Opened the car up, jumped in and pressed the keyless start button. All the lights in the dasj sprung to life doing their usual thing but the engine did not turn over. I tried a couple more times without any luck. Left the car about 15 mins and came back to it and it started up straight away!! I assumed it was just a small electrical glitch that has rectified itself do I used the car all day turning it off and on 4 times with no problems.
Then that evening, I drove 4 miles to pick my wife up from work, pulled into the carpark and turned iff the ignition while I waited. When I went to start the car the same thing as the morning happened. All lights, radio etc on as usual and car going through the normal check on airbags, abs, glow plug etc but did not turn over. I can hear a loud click noise coming from a black electrical pack attached to the battery in the boot (trunk). Tried the turning key left for a few seconds and the right to use the aux battery to start but it makes no difference. Also pulled the fuse 41 and disconnected the battery in the rear and the negative terminal for the battery under the seat-still no difference. Im stumped!
I have the rear battery taken out and I will get it tested today. However, I noticed there is a sticker on the side of the battery saying "recharge November 2014!" It also is only 820 amp and not a dry battery as I would expect in the cabin.
I was wondering could this be a Kessy issue? The doors lock unlock as usual, the light around the keyless start button illuminates as i get in (so it must be recognising the key?!) and the black buttons on the door work as normal. I have already put a new battery in the key incase this was the problem but no luck.
Any help would be much appreciated as I am at a lose here. Thanks again
