1 - 16 of 16 Posts
VeeDouble
Discussion starter · #1 ·
I just picked up my first Touareg (2008 v8) last week and think I would like to modify some settings... From what I have read around here, the Ross-Tech kit is the way to go... but on the Ross-tech site it appears that they offer multiple kits...
VCDS Ultra Professional Kit$1,199.00In Stock
VCDS Super Professional Kit$899.00In Stock
VCDS Professional Kit - USB Interface$599.00In Stock
VCDS Professional Kit - Serial Interface$599.00In Stock
VCDS License with HEX-USB+CAN Interface$349.00In Stock
VCDS License with HEX-COM+CAN Interface$329.00In Stock
VCDS License with Micro-CAN Interface$249.00In Stock
VCDS License with KII-USB Interface$249.00In Stock
http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AF2X2&Category_Code=VAGCOMhttp://www.ross-tech.com/Merchant2/...erchant2/merchant.mvc?Screen=PROD&Product_Code=VCDSLiteReg&Category_Code=VAGCOM
Which one should I buy...?????
Thanks in advance! :)
Discussion starter · #5 ·
Thanks for the responses! I already have a laptop, and don't really need a case for the cable... So I guess from here I buy the $349 kit (VCDS License with HEX-USB+CAN Interface) I am assuming this is USB? Is it basically a cable and I download the software online from RossTech? Thanks!
Yep - that's what the USB in the name means.
Yes, we will send you instructions of how to download the software. You perform a test of the cable connected to your computer and car. It activates the software and off you go in the land of Diagnostics.
Discussion starter · #8 ·
Wow, thanks for the responses... a bit late though, I already purchased my ross-tech cable over a month ago and vag'd tons of things. It's a great product - and is relatively easy to use!
Well if you have and some are not documented, perhaps you'd care to share? Like enabling the passenger eject button, activating the impulse engines without engaging the inertial dampers (known to drain the battery)....
siberian
1 - 16 of 16 Posts
