TOUAREG v6 3.2
..well that narrows it down a bitMost fuel filters are located between the fuel tank and the fuel injector.
erinender987 said:Most fuel filters are located between the fuel tank and the fuel injector. Your owners manual should have the location of the fuel filter listed. If the manual doesn't list it's location, you can ask at your local auto supply store or car dealership parts department
Thanks for share . Its very helpful for us .
English said:..well that narrows it down a bit![]()
I'm not dumb. But where exactly? Service guy at the dealer talked me there is no fuel filter. Its life time. That's why I'm asking you guys if you know exact location of the fuel filter.verdeo said:indeed...
krussellm said:In tank with pump, non-replacement item, unless of course your pump dies.
Thank you so much that answered my question. Yea it is v6LocoLobo said:The V6 has it in the tank? The V8 has two...one on each side under the rear seats. And yes the filter is integrated with the pump.
(drying my eyes) thanks, I needed a good laugh...verdeo said:I think VW did not intend the Touareg for dusty or dirty conditions, therefore it is not replaceable. I only use mine on super highways and if it's too dusty or dry I always keep it in the garage, since it is air conditioned and filters incoming air.
I am always concerned about preventative maintenance and I realize what a delicate vehicle the Touareg is. The fact that the Touareg is probably the 7th or 8th VW I've owned ...all previous VW's I've treated the same way...doesn't bother me too much, since I understand how incompetent VWAG is at designing vehicles for adverse conditions.
If you are using it in areas that are dirty, it's your fault. Let's not try to shift the blame on VW. They are in Germany!
