Have an '04 V10 with 110k miles. I recently changed the fuel filters (2 wks ago). This weekend, I noticed there was a small amount of diesel dripping below the Touareg. I have double checked all of the connections/fitting at the fuel filter. Everything up top is dry. I have removed the belly pans and inspected from underneath with the engine running. I could not identify a source or see any fuel dripping. It does appear to be coming from the drivers side. Is it possible that the source is the aux water heater? Does it have it's own exhaust or dump into the engine exhaust? Could I have introduced some air in the fuel circuit that prevented the aux heater from firing correctly and cause it to dump fuel? Can I test fire the aux heater via VAG-COM? Any suggestions will be appreciated.
Tim
Tim
