Spare Wheel Carrier
4K views 8 replies 6 participants last post by  Odessa
Going to be doing an outback trip (Cameron Corner) in early October and I am looking for a spare wheel carrier, preferably one that comes out of the tow bar and can tilt so we can still open the rear boot. I am not towing anything at the same time. Has anybody found any economical options?
Here is a list of results from "search" for "Spare Wheel Carrier" in the Australia/NZ section of the forum. Search results for query: spare wheel
Some results are quite old, some are very recent, but it will give you an idea on what others have done in this regard ;)
owns 2015 Volkswagen Touareg R Line
Reactions: Crispy3
#3 · (Edited)
I still have the one Alex G made for my previous MY05 V8. It was designed to fit the hayman reece tow bar as it came out slightly more. It appears it will fit the OEM bar also but will need to drill a second hole....... not sure how you would go with the 7P you could try and measure up
actually sorry just had a thought ... your stud pattern may be different ....
but...surely that could be a relatively easy correction?
I had the stud pattern 're-aligned' on our spare wheel carrier on the caravan recently, to accommodate the 7P spare wheel, which as you point out, is a different pattern to the 7L
I purchased a tyre trek Home - Tyre Trek second hand for my 7L. I had to fit a wheel spacer and redrill it to fit. Perhaps they could build one to suit your Touareg. I also carry a Jerry can full of water. I can also lift the rear glass without swinging it out of the way. Very happy with it.
I have the same one on my car, I had to weld in a 50mm extension to fit the jerry can mount though on my r5 with 17” rims. I can also open the glass hatch without opening the tyre carrier. I find it affects the departure angle with the standard VW OEM towbar though.
239219
I have exactly what you want - See post here. Previous offers fell through, so it is available. PM if you want to know more.
Includes licence plate holder with light connected to 7-pin flat plug.
Good Man Hoodie !!! Do someone right and well. Just noted Unky's prob with no interest and was amazed
