1 - 20 of 21 Posts
helluvadeal
Discussion starter · #1 · (Edited)
I'm back again with this problem car of mine.
I just replaced the starter on my 2015 3.0 TDI. The car cranked beautifully and ran great for a day, but then the next day it started to crank sluggishly and now won't crank at all and I'm getting the following two error codes:
5463 - Starter Control; Returned Message P3052 00 [167] - 50 Short to Plus
22944 - Shift Solenoid 2 P0977 00 [171] - Short to Plus
This is my first real car that I've done a lot of work on so I'm still figuring a lot of things and, especially when it comes to electrical.
Based on what I'm finding on Google, my theory is either a bad relay or a the grounding strap that goes from the starter/alternator to the frame is bad...but I don't know why I would be getting the shift solenoid short code as well.
edit Battery is good, was just replaced a couple of months ago and is always at about 12.6V when not running.
edit#2: Solved!
I forgot to update this post with my solution.
It turned out to be a bad connection on the main engine grounding lug. I'm kicking myself for it being so simple as I wasted a TON of time, effort, and worry on this. It looks like what happened was when I connected the grounding lug when I put in the engine, the edge of the lug was hung up just enough on the bolt to keep it from making a good connection which is why I was getting the intermittent starter issues followed by it suddenly not working. I pulled the lug off, reseated it, and tightened it up and the car started right up.
In other news, I have a new multimeter with some fancy leads, a starter tester switch, and I've gotten real good at pulling this alternator and starter off lol. Thank you very much for your input, fellas!
While I'm waiting on someone else to bring the relay tester back to O'Reily's for me to check out, do you guys have any suggestions for where I should start troubleshooting?
VCDS scan below:
Friday,17,February,2023,09:26:21:48004
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVGEP9BP1FD007794 License Plate:
Mileage: 50517km-31389mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
5F 62 65 69 6C 6D 72
VIN: WVGEP9BP1FD007794 Mileage: 50517km-31389miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 B HW: 7P0 907 401 K
Component: 3.0TDI EDC17 H21 0001
Revision: 56H21--- CVN: 854114CB38D3FF8238D3FF820E1FC39E
Coding: 292A4012233600050000
Shop #: WSC 08302 002 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401B 001002
ROD: EV_ECM30TDI0117P1907401B.rod
VCID: 2F3B130FB796F4334E9-807A
VINID: 9E65D58094A00565000071C910BC177B53
1 Fault Found:
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 50517 km
Date: 2023.02.17
Time: 10:22:57
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: -5 °C
Intake air temperature: -2 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 11.700 V
Unlearning counter according OBD: 40
Engine control module reset status-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 2
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 44
Accelerator pedal travel: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 HW: 0C8 927 755
Component: AL1000 AISIN 130 2882
CVN: 7A02EA0D
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 6E85CE0B701CBD3B05F-803A
1 Fault Found:
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 50517 km
Date: 2023.02.17
Time: 10:22:57
Engine RPM: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
ATF temperature: -2 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 40105438563944
Coding: 5B7613C34924255ADAFBC89C92D6A4607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC164832640AF2B4BB-8018
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77ABEB6F0FC6FCF3D69-8022
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3215000078988013
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686200A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 78A9E8530258F38BDF3-802C
1 Fault Found:
0291 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 153
Mileage: 50517 km
Date: 2023.02.17
Time: 10:22:54
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001069413902
Coding: 26000096963C5D010020480300005D4C431C6608A2014261000000008040110000000000000000
VCID: 6A8DC21B4C74511B597-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150424 033 0021
Serial number: 90243400150429130006
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20547669
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000002704150157
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01EB658C
1 Fault Found:
01592 - Air Quality Sensor (G238)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 50517 km
Time Indication: 0
Date: 2023.02.17
Time: 10:22:52
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28291510602686
Coding: 510504
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D14CA30E10676B83B-8010
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04Z H10 0043
Revision: -------- Serial number: 003NK003ECB0
Coding: 00000000000000000000000000000000345A
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D34FBF0B1E6053BA1-8016
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R153030MJCY
Crash sensor for side airbag: driver side:
Serial number: 3575LRB405P37J0OD9HX
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405P37T889OVI
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB405937LCS80NC
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB405937LCSHGHW
Crash sensor for front airbag: driver side:
Serial number: 3557BRB405D36F9UA21
Crash sensor for front airbag: front passenger side:
Serial number: 3567BRB405D36F9U921
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AG
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OE50002Y
Coding: 000CD5
VCID: 3D2739476D7A16A3CC5-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0086410 TRW 20150321
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 A HW: 7P6 920 983 A
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658050515592014
Coding: 8B7733022B08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
VCID: 3D2739476DFA16A3CC5-8068
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 M HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6042
Revision: -------- Serial number: 00000001828386
Coding: 000103AD00
GVL: FB4F40655D7F000000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 42DD4ABB1404695BB17-8016
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 42103H09355701851530
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000145238293
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34311C635E30D7EB33B-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0366707975
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDB434F67F604B3DE9-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0366579435
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000147656581
Coding: 011D17205E00453005080000
VCID: 7AADF25B3CD4E19BA97-802E
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 50517 km
Time Indication: 0
Date: 2023.02.17
Time: 10:22:52
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0365944967
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 083153552
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO3498679K
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO3495849G
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65017603
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 50517 km
Time Indication: 0
Date: 2023.02.17
Time: 10:22:55
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002511408
VCID: 75B7E16715CA8EE3C45-8020
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000147957471
VCID: 48C9589332B8430B6F3-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1541700469
Coding: 01040200
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 3635266B48CCC5FB0DF-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: --------------
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW51.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156D 0F8258134
Coding: 020007010000000001
VCID: 2411EC23EED0476BA3B-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273E20FB007298
Coding: 020200050040E1EF51022B0E00000003F00001030000000000
VCID: 3C21344376601FABFBB-8068
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9RX8004KU
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000148169347
Coding: 011817200000253005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000015459
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45D751A7052A5E63945-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0367736653
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 372B2B6F4FC63CF3169-8062
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0227271
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 117500628
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000147985700
End----(Elapsed Time: 02:17, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Before we get to voltage drop testing, post the following MBVs
Code:
                Address 19: CAN Gateway  (7P6 907 530 J)
06:03:48
  IDE00019   Voltage terminal 30 14.2 V
  IDE01833-MAS03159   Battery version-Manufacturer Varta
  IDE01833-MAS04490   Battery version-Size 110 Ah
  IDE01839   Battery charge level 88 %
  IDE01840   Battery condition for display 90 %
  IDE01842   Usable battery charge 84 Ah
Code:
06:03:48
Sorry that took a few minutes, I'd never used that function on the scanner before, took me a minute to figure it out.
So the battery is pretty low, I've hooked it up the charger.
I've spent a lot of time out in the car with the electronics powered up (but obviously not running), could that have drained it so much? Or is something else going on?
Address 19: CAN Gateway (7P6 907 530 M)
11:14:50
IDE00018 Voltage terminal 15 11.6 V
IDE00019 Voltage terminal 30 11.5 V
IDE00030 Status of actuator test not active
IDE01833-MAS03159 Battery version-Manufacturer Moll
IDE01833-MAS04490 Battery version-Size INIT (110Ah)
IDE01839 Battery charge level 67 %
IDE01840 Battery condition for display 70 %
IDE01842 Usable battery charge 24 Ah
One second... I just noticed your super low mileage.... why isn't the dealer fixing your starter issue under warranty? :unsure:
I bought this car from Copart, so no warranty on it.
The engine was hydrolocked so it was written off as water damage, but other than the engine being seized up, there's no sign of anything having gotten wet, inside or outside the car.
There's plenty going on.
Your new battery wasn't coded by the looks of it.
It's also quite low.
But you also have a short.
What charger are you using?
You should probably code the battery so the BEM knows it's dealing with a new battery.
Did you use the proper replacement, or some rado crap?
Discussion starter · #9 ·
I'm using a NOCO Genius Pro 50 battery charger. Pretty gnarly charger, my sister got it for free off of Amazon Vine and gave it to me for a birthday present.
I'm pretty sure it's an Interstate battery but I'll have to double-check the brand name, I got it from Costco.
And I'll go code the battery right now.
I'm assuming I'll need to wait until the battery is charged before doing anything else?
Discussion starter · #13 ·
No... the battery you took out was....... Flooded?
The one you put in is..... AGM
One of these things is not like the other!
The old battery was also AGM, but I've no information on the exact make and model.
The new battery is an Interstate MTX-95R/H9, one of their top AGM batteries.
And from what I've read, there's no issues replacing a flooded battery with AGM except in older cars. Is that not the truth?
Discussion starter · #15 ·
If you had AGM originally, then I agree. Different specs for different regions and options. I have a starter battery post with lots of specifics if you want to get a feel for what I see.
Yeah I'd love to take a look, do you have a link to it? Btw, I read your post on aftermarket scan tools, lol now my newbie ass is all kinds of paranoid.
And random question about my Touareg. Could a banged up Terminal 50 cable connector (where it plugs on to the starter) potentially be the cause of my issue?
I ask because when I was trying to pull the old starter off, the clip on it was pretty banged up.
I can only assume whoever had the car before me and was trying to get the bad engine to run messed with the starter and dinged the clip.
Based off your codes and description, I'm going to say you have a poor ground, especially if the engine has been replaced. I would say the main ground cable/s for the engine weren't attached properly, or were damaged. Did you have similar issues with the original starter?
Discussion starter · #19 ·
Sorry, been away for the weekend helping my parents out.
The original starter was cranking sluggishly, and sometimes it wouldn't start until I jumped it with another car. That's why I suspected that the starter was bad. But I wasn't getting the error codes about the terminal 50 problem.
I will go out and double-check the grounding cables for the engine. I only remember seeing one.
1 - 20 of 21 Posts
