2014 TDI starter battery replacement - probably millionth post on the subject by now
5639 Views 78 Replies 11 Participants Last post by  SaVAGeSoot
Well, I've had my '14 since '18, and although it's never not started for me, I did notice it cranking slowly during our winters up here, have had a bunch of codes for low voltage events over the years, have had locks and aux heater codes, and other low voltage hints such as the EMS stepping in and turning things off to ensure it always starts, etc.
I've also been randomly checking it over the years, and have been always seeing it in the 11.6v - 11.3v range after being parked for as little as a few hours or overnight. I suspected the battery was the original, and I feel it had lasted long enough given its environment.
I was very tempted to purchase just a random battery in order to be cheap, but though about he inconvenience of having issues or getting stranded vs saving a few hundos and decided to go OEM.
Prices up here are just stupid on these things.... just for reference.
Rectangle Font Screenshot Parallel Circle
Dealership deal, but at least it's a VARTA :confused:
Font Art Brand Electric blue Circle
Font Auto part Automotive tire Rim Automotive wheel system
I was not expecting it to be this gigantic... typical "normal" battery on right for comparison.
Don't skip your Wheaties if you want to put one of these in... she's a pig.
Musical instrument Gadget Audio equipment Gas Electronic instrument
Removing the driver's seat was a PITA, and there's no hinged seat, so all four bolts need to come out.
Getting the electrical connectors unclipped is even more of a PITA.
Lastly, the biggest PITA is operating the battery cover corner clips to get the cover off.
After a lot of struggling and swearing, I finally got a visual confirmation that the battery was original. An interesting side note... my carpet was already cut which lead me to believe that it had been previously replaced until I saw the details on the battery itself.
Audio equipment Gadget Gas Electronic device Auto part
Communication Device Automotive tire Gadget Mobile device Font
So I wrestled this mammoth out of there, and got the new one in. I hooked up the normal battery with jumper cables on the posts in the engine bay so I wouldn't have to deal with lost memory setting anywhere, etc.
Then I noticed that my new battery is already almost a year old.... oh well... I guess it had to travel over the pond and I'm sure the warranty starts on the purchase date, etc.
Motor vehicle Automotive lighting Fixture Gas Machine
So after all that, the egg started and drove without any drama.
I did take two quick logs of the different starts pre & post change, and I did note that the controller was coded for a VARTA even though the battery was a MOLL brand. Got 8 years out of the "incorrect" coding, so I can't complain.
Here are the stats. I will look at the values again after I drive a little so it gives the system a change to put some more charge into this battery... I'm sure the dealer has had it on the shelf for a while.
Original Batt said:
Mileage: 149606km-92960mi Repair Order:
Address 19: CAN Gateway (7P6 907 530 J)
10:38:49
IDE00019 Voltage terminal 30 11.5 V
IDE01833-MAS03159 Battery version-Manufacturer Varta
IDE01833-MAS04490 Battery version-Size 110 Ah
IDE01839 Battery charge level 54 %
IDE01840 Battery condition for display 50 %
IDE01842 Usable battery charge 15 Ah
New Batt said:
Mileage: 149635km-92978mi Repair Order:
14:12:17
IDE00019 Voltage terminal 30 12.1 V
IDE01839 Battery charge level 76 %
IDE01840 Battery condition for display 80 %
IDE01842 Usable battery charge 58 Ah
I didn't bother taking pics of the process at it was actually snowing while I was doing this crap and everything was getting wet as I was doing it outside.
See less See more
7
Reactions: 3
1 - 20 of 79 Posts
I just changed mine yesterday,but at the dealer, 2016 TDI bgt new in 2018,so the battery was sitting for 2 years. Why did you choose an AGM battery, the OEM is a wet cell unit? I could have gotten a year more out of it,but the load test showed 50% capacity and I've been stuck before with a dead battery. US cost was $300 + $100 install. If I get 6-7 years out of it I'll be happy.
I didn't. I even posted picture of the Lead-Calcium unit I bought above
The first picture is an AGM so guess you mean the one in the next pictures. VW don't make batteries so not sure of the advantages of a VW OEM which is a Varta with a VW sticker on it unless the price is less.
The first pic was the aftermarket option example. The comparison pic was what went in. As per my post, I wanted the BEM coding, and if you read about the various battery technologies, it appears that the OEM option has a good reputation/track record.
I also have more faith in a German made unit vs some China crap or bargain N/A unit.
Reactions: 3
The standard fitment in Europe is an 020 AGM. I assume in Canada a Lead Calcium is required as there isn't any stop/start :unsure: You're right fit the best, peace of mind alone makes it worth it.
Yup, the only stop/start here is when it stops starting due to cold :D
And because I'm anal and nobody cares, I've checked the battery stats again, after a few weeks of daily duty.
I was disappointed to see them still low.
19:04:38
IDE01839 Battery charge level 74 %
IDE01840 Battery condition for display 70 %
IDE01842 Usable battery charge 59 Ah
So, since I'm not seeing these values higher, I'm suspecting that the dealer didn't keep this puppy fully charged before selling it to me. It appears that my daily commutes aren't providing sufficient charging fast enough, so I busted out my charger and threw it on.
Product Motor vehicle Font Gas Electric blue
Automotive exterior Motor vehicle Gas Auto part Font
Motor vehicle Audio equipment Gadget Gas Automotive exterior
Motor vehicle Audio equipment Gas Auto part Vehicle
I'll take another reading with VCDS tomorrow after a daily use cycle to see if the stats are higher and if the system keeps them maintained there or not.
See less See more
5
New stats after charging...
16:23:23
IDE00019 Voltage terminal 30 12.4 V
IDE01839 Battery charge level 94 %
IDE01840 Battery condition for display 90 %
IDE01842 Usable battery charge 84 Ah
I suspect my new battery was sitting a while as well, I will be going on a 1500 miles road trip that should do the trick, if not, back to the dealer for another battery.
I think that there are so few Touaregs in our location the chances of a really fresh battery is pretty slim.
I've actually been reading about the proper way to charge this type of battery, and it would appear that my charger is not capable of charging to 100%..... apparently they need a charging voltage between 16.1-16.5v to fully charge, which explains my "stats"..... I did look at the voltage my charger was putting out and it was never above high 14s......
I'm not sure that our alternators will regulate the voltage that high either, but I may log the output during a commute just to get a better idea of what the system is doing.
Well, I've confirmed my suspicions on my commute into work this morning.
I logged the parameters and confirmed that the system does not increase the voltage sufficiently to even fully charge the battery to 100% level. Below is a log showing its exact behavior. I may try to put the charger back on the battery with a manual setting of high current to see if I can forcefully charge the battery to a higher level.... just not sure that would yield any benefits based on what I'm seeing.
Log #565328
Log #565328
Good morning from Aussieland -- a very interesting post - I note that with my "smart multi stage charger" (Projecta brand) that the normal program set to Calcium battery the charge voltage does not go above 15.1 volts, however my redarc DC to DC charger will output 15.3 volts on the calcium setting ( I only use the redarc for my caravan AGM battery though) but. your post has prompted me to just check the output of the redarc BCDC12/25. I will now go and see what the vehicle does and check the battery in the car - Thanks
Keep us posted. I'm going to also set my charger on manual to try to force a higher charge through increased current.... Just waiting for all this rain to stop, so not sure when I'll get to it.
I've been searching for a proper battery charger (for this type of battery), and it appears that they more or less don't exist... so unless you pony up big coin for something like a VAS5903 you will never fully charge this type of battery!
WTeeeefffffffffff ????
Looks like my only option is to get a proper, manual (aka dumb) charger so that I can control the voltage and amperage myself as far as the settings.
Hi SaVAGeSoot The battery types that you posted in photos reflect that they are calcium style batteries -- they are a variant of that type with added silver https://productsheets.varta-automot...93.519275033.1655847879-1778870645.1655847879
So I see no reason why a quality multi stage charger would not do the job
Rectangle Font Parallel Pattern Number
See less See more
As per my earlier mention, according to my research, they require a 16.1-16.5v charge at 10% of capacity current. Even your listed charger can't keep up 😉
Check out post 9 to see that I only got 84ah into the 110ah "capacity" with my charger as a result of it not being able to supply the voltage that high.
Hi SaVAGeSoot Not quite sure how you determined that you need such a high voltage to charge your battery would you please let us/me know, as far as I can determine there is nothing different about the type of batteries shown in your photos(post #1) and those generally available for automotive lead acid "style" batteries that require a charging voltage irrespective of its chemical style -- each cell within L.A. batteries produces around 2.2 volts per cell and the nominal charge rate is 2.4 - 2.45(2.5) volts per cell however different chemical additives permit variation within that range. Lithium batteries are a totally different proposition of course while using similar voltages the charging profile is different and it is not good to float charge them as one does a lead acid battery.
I guess what I am saying is that you may well be damaging/shortening battery life of your battery with such a high charge voltage, unless of course there is formal advice to the contrary.
See less See more
Here are two extracts from some of the numerous articles I've been reading on the subject. Depending on how much time you want to kill, you can easily find more with some google searches.
https://a6s.info/en/electronics/146-charge-calcium-battery said:
Calcium battery charging algorithm
If instructions for charging a calcium battery were instructed to write to me, then it would look like this:
Estimate the state of charge of the battery by the rest voltage or the indicator on the case.
If the rest voltage is below 12.3 V (or the indicator is not green), charge the battery using a charger.
Disconnect the battery from the on-board network.
If there are blockages, turn it out.
Connect the charger, having previously set the charge current to 10% of the real capacity, and not from the one that is written on the case.
Charge until the voltage reaches 14.4 V and the charge current drops to 0.1-0.3 A.
If you are going to travel in the near future, then simply connect the battery to the car's on-board network.
If you are not planning to travel, additionally charge the battery at 16.1 V for 40 minutes.
If the density of the electrolyte up to the 8th point is normal, then it is not necessary to charge with a voltage of 16.1 V.
The same is true if the indicator on the battery case turns green.
  Lead-calcium Battery Charging
  The method and the process of charging any battery is always crucial. Never purchase a battery without asking for directions on charging it because you might ruin your battery after a few days. Therefore, you need to be keen on your lead-calcium battery because you cannot afford to destroy it.
  The ordinary lead-acid battery requires a charging voltage ranging from 2.15 Volts per cell to 2.35 Volts per cell. However, the charging voltage of a lead-calcium battery is 14.8 volts. This voltage ensures that the recombination process in the battery occurs appropriately.
  The above-mentioned charging voltage of 14.8 volts indicates that it will be almost impossible to trickle-charge a lead-calcium battery. If you are using the battery on your car and the alternator can charge it, it will always ensure the alternator is actively working.
  However, you need to be careful with this calcium battery because it has a low voltage but a high current. No one can think of making the terminals meet because it will produce a massive fire or explosion.
  The good thing with lead-calcium batteries is a low self-discharge rate, meaning that it will work for an extended period. However, the lead-calcium positive plate can grow because of oxidation caused by battery overcharge. Therefore, you should be careful not to overcharge the battery.
  If your battery discharges significantly lower levels, you can connect it to a charged battery using jumper leads. You will need to connect the smart charger to the discharged battery, and it will start charging instantly. Leave the batteries connected for about 15 minutes, after which you can disconnect them, and the smart charger will continue charging the battery.
  It is advisable to charge your battery several times a month regardless of the season. Also, a calcium battery requires a special battery charger, unlike other batteries. You can fully charge a lead-calcium battery with a charger producing a voltage between 16.1 and 16.5 volts.
  Using a charger that supplies a voltage below 16.1 will mean that your battery will be partly charged. This means that a car alternator will not charge the battery fully unless it can supply the required voltage for an extended period.
If you have sources to share, or if you can otherwise explain why both my current charger and the vehicle's system aren't bringing the battery up closer to its full potential, I'd be all ears!
1 - 20 of 79 Posts
