hi guys, i have a problem with my air suspension. I replaced the air compressor 3 month ago and everything was working fine since then but 2 days ago i noticed when i was driving that the front was sitting lower and finally the red running gear fault appeared. I plugged vcds and i have some code, i will post it later. First it's weird because i can hear my compressor kick in and out , secondly when on park i can turn the knob to x-tra offroad and the front and rear go and but as soon as i go bask to normal the front go down completely and the rear move down just a little bit.
this is the code i have
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
Shop #: WSC 31414 000 00000
VCID: 66C9BFCA52A8B211F57-515A
1 Fault Found:
00492 - Body Pitch Angle from Level Control Module
008 - Implausible Signal - Intermittent
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
Shop #: WSC 00000 000 00000
VCID: 3777228E4582FB999E1-515A
No fault code found.
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 36692F8A42880291857-515A
4 Faults Found:
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
01780 - Sensor for Vehicle Leveling
003 - Mechanical Failure - Intermittent
02250 - Function Deactivation; Valve Duty Cycle
01772 - Signal from Level Control Pressure Sensor (G291)
i clear them and after the only ones i can see are 01400 and 02250
i need help guys to fix it and trade it in asap
Coding: 0000003
1 Fault Found:
Coding: 0015521
4 Faults Found:
