My MFD is acting up. When the car has been sitting a while and is first started, the display is nice and bright and you can read everything very clearly. After about 10-15 mins It starts to fade away to the point you can read anything. The display is still somewhat lit up but you can see anything.
I have found several clusters on flea-bay and was wondering if I could just swap the cluster out with out any issues?? I know the odometer will be wrong but I can have that corrected by someone with a Vag-com correct??
I have the red display..my touareg is an 06, would it matter if the cluster was from an 04,05 as long as it had the same engine??
