This thread will not provide a definitive answer, I am afraid, but rather suggest a possible method of measuring the difference between standard fuel without additives and premium fuel with additives.
Volkswagen recommends in the user manual that premium fuel be used (chapter Fuel, p. 315 in my case). I have always wondered whether this makes any real difference and finally decided to measure that difference somehow. As I am mainly interested in the alleged cleaning properties of premium fuel, I have used the value IDE05857 DPF statistics: current measured charging rate in Address 01: Engine in VCDS. This method shows the real charging rate of the particle filter in grams per kilometer. This method has certain caveats because the rate is influenced by other factors such as the driving style (acceleration, towing, using the low-gear transmission), weather conditions (temperature) and quality of fuel from different manufacturers. This is why a certain fluctuation needs to be tolerated (I would allow at least +/- 0.005 g/km) and not be attributed to better properties of premium fuel. What probably matters more than the absolute values for standard fuel and premium fuel is the difference between them. I used standard diesel and Shell V-Power Diesel/Verva Diesel/Diesel +, which are just different brand names for the same product from a local refinery. According to the manufacturer, the additives in the premium fuel are oxidants supporting fuel combustion, which results in less soot. The results are interesting:
Address 01: Engine (7P1 907 401 F)
standard fuel: IDE05857 DPF statistics: current measured charging rate 0.0409 g/km
premium fuel: IDE05857 DPF statistics: current measured charging rate 0.0129 g/km
The drop is so significant that it would be tempting to conclude that the premium fuel did work and was worth buying, but it is too early and more data and longer measuring periods are needed in my view. Therefore, if you can provide the data for your car or have a different method of measuring premium fuel effectiveness, please post them here.
