Okay, okay. I like the pano roof to sit under,
You're easily swayed
ST, I don't how you arrived at your conclusion, reading the words that accompany the pic, I read it completely the opposite, ie because they cut a big hole in the roof and made it weak, they had to reinforce it with a 'bonded, read glued' frame to support the glass and assist with side impact collision. They would not have to do this if they didn't remove the cross beams and cut a hole in it.
Looking at the pic, and using structural geometry of the two scenarios, it is night and day of the difference. In addition, if the hole and surround is 'stronger' wouldn't they do that to the entire car to make the whole car stronger but lighter?
At the end of the day, people choose a pano for reasons beyond structural integrity, but I'd like to also put it on the table that at the end of the day, steel is the principal structural material in a car, particularly for areas where a manufacturer has deemed it critical enough to employ expensive steel, ie hardened/high strength steel, there is just no way of looking at the situation other than that to remove steel component is to remove potential strength of a vehicle.
All other annecdotes aside, don't you also think that if the Tiguan example holds water that VW's spin doctors will be shouting from the roof (pardon the pun) about how great it is, and publish some analysis?
Also, don't you whether you remember or not, but back in the eighties sunroof (the flip up kind) used to be available at auto accessories store that people can self install by cutting a hole in the roof. In Australia at least, what was discovered was it weakened the vehicle significantly and was banned from sales. The manufacturers was up in arms and started incorporating metal frames around their sunroof kit saying the frame 're-strengthened' the roof ), more furfy, and the ban continued....
