Hi all,
I have been searching both this site along with the web for answers, but have not found the fix. Here is my issue:
I had a passenger bulb that would go out from time to time and a driver side bulb that looking like it was virbating. I decided to replace both bulbs so that I can keep the color match the same (HID bulbs).
Things worked good for a few days. The passenger side started to go off again! A few days later i was getting out of my car and the headlights left on sound was coming from the car when exiting. What was weird was my headlights were off!! Finally after messing with the key and headlight switch I got the headlight reminder noise off.
Now I have not low or high beams!! I have checked the fuses, tapped on the headlights, checked the connections, etc.
What the hell should I do next??
Side note the light indicator on my cluster would come on when I had headlight failure.
Hope someone has an answer!!
Thanks,
John
Thanks,
John
