Day 1: Rear Doors: Audison Voce.
I was pleasantly surprised when I went to use my new triple square bits (as indicated in some threads that this was the bit set that was required) only to find that the door panels are held on by Torx screws.
The touareg is a decently quiet vehicle to begin with, but I always add a bit of deadener to strengthen the mid bass response. The doors inner plastic panel requires some as it is a bit thin and very flexible around the speaker mount. When I looked within the door panels, the upper had an odd very thick deadener already applied, the middle had a butyl rubber/silver foil, like dynamat, and the bottom behind the speaker has none.
I was toying with surface mounting the tweets but that would require cutting into the surrounding plastic around the tweeter grill. One mistake would cost hundreds of dollars to fix. I opted to mount the tweeters behind the door grill when I easily discover that I could screw/bolt them to the door panel and hide the screw heads behind the tweeter grill.
First round of pics.
