So the switch knobs next to the cup holders. They sawy low and high then have a picture of 4 wheels also what do they all mean? I read the manuel but it doesn't show it
I was just confused, and they don't make it easy to understand for us ladiesYeti said:You should have saw it was in low range with looking at the cluster before you ever took off. It lets you know via a message and display of the system in the MFI. Hopefully you did not drive far like that on dry pavement.
Leave the knob in high and pushed down. Low range will more then likely never be something you ever use/need.kemiqb said:I was just confused, and they don't make it easy to understand for us ladies![]()
This is really a pain and dangerous. It's a shame they don't have an on the fly shift like the Durango does, amongst others. After all if you feel you are starting to get stuck but are still moving, having to have it in neutral by the time you do all that, you're going to be stuck for those of us who don't drive on "sunny pavements"Just remember what Stalker said, transmission shifter needs to be on neutral while you fiddle the high-low knob
One word:siberian said:This is really a pain and dangerous. It's a shame they don't have an on the fly shift like the Durango does, amongst others. After all if you feel you are starting to get stuck but are still moving, having to have it in neutral by the time you do all that, you're going to be stuck for those of us who don't drive on "sunny pavements"
siberian
You wouldn't plow into an unknown stream without first checking depth, right?siberian said:By placing a car in neutral?????????
siberian
I'll vouch for that, if only because it allows you to also lock your center diff (which isn't an option in high range).Oh trust me it does give you more traction... putting it in LOW pulling up a 7,200 pound trailer up a 30 degree mud slope... it's there for a reason.
siberian
