Got another Touareg - 7P 4XMotion
1.2K views 20 replies 6 participants last post by  Brendanm
Deal came up for this bad boy and I had to get it. Has an air suspension fault after the previous owner had tyres put on it, and the shop didn't put it in jack mode. Has a coolant leak, looks like valley.
With the bad out of the way. It's a MY13, blue, 4XMotion (low range and locking centre and rear diffs), air suspension, adaptive cruise and Dynaudio package. 156,000km. No oil leaks, no chain rattle, no injector seal leaks.
I'll do a couple of threads on the air suspension and valley leak repairs.
Nice car!
Considering it has a coolant leak did you buy it with RWC?
owns 2013 Volkswagen Touareg V6 TDI
Pulled intake etc off to do the valley leak today. Valley was near full to the brim of coolant. Cleaned it up, cleaned up cooler, cleaned up adaptor plate. Put on adaptor plate with new seals. Tested coolant bypass valve, leaking out the shaft, so will order one of those.
Also cleaned out both intake tract valves, intake horn, and intake manifold.
This is what mine looks like at 225k...
ya but we know how it is in Onterrible - y’all drive 6 hours each way to commute. OPs was probably driving Miss Daisy for most of its life.
