1 - 4 of 4 Posts
dragline1570
Discussion starter · #1 ·
VW Touareg 2004 V10 Engine in Bruthen, VIC | eBay
Just need a sanity check one way or the other.
I have contacted this guy about the engine a few times.
First he had it listed at $1500 about 3-4 months ago and I offered him $350 which he knocked back.
I know individually the sum of parts are worth well over $350 and for that matter $1500. But as a failed engine the block is worth $0 and the rest of the components worth in my opinion not much more.
For example who would buy the turbo's and fit them to their V10, not many if any at all I would bet, without at least having them serviced but most have fitted new units and the turbo's are a very specific item on the V10 and you would be very hard pressed to find another application.
Cams and lifters would be shot or well on the way.
So you would be just chasing other specific stuff like exhaust manifolds, heads, timing module. alternator, starter etc. By my counting I believe about 2 members have posted about a full rebuild and maybe a handful more about heads removed and replaced.
I sent him a message today asking about his Tandem pump as mine is leaking and it may be from the join between the vacuum and the fuel pump. I just want a unit to strip just to see if this can be resealed and if it was ok inside maybe reuse it. He wanted $200 plus freight which I said given you only want $1000 for the engine that is steep and a new unit is only $430 usd. then I offered him $300 for the pump and turbo's which he also declined to accept., (am I a low baller as you yanks call them?)
Anyway as a final I told him that his potential customer base for a damaged V10 was next to zero and when he has decided that he cannot sell it call me before he scraps it as I will pay more than them.
Anyway am I a heartless person or am I being realistic, but please be gentle.
Regards
Drag
Much like real estate, this engine is only worth what someone is willing to pay for it. All you can do is to put a bug in his ear and talk him down. Yes, there are likely some serviceable items that can be stripped off, but the fact of the mater is that it was pulled as blown motor. Unless he has pulled it completely apart and documented the condition of items like cams, gears and pump, it's a complete unknown.
Low ball the snot out of him.
I like the idea of it being a test platform for your own engine. Try it on the test piece first in case things go wrong, then you don't mess up the good engine.
You are also right in stating that the parts value is low. If I had to drop my engine to replace a major component, I wouldn't want used parts from a blown engine. So it's probably only worth scrap value.
1 - 4 of 4 Posts
