381 - 400 of 436 Posts
Here you go, this will get it going for a CR Module 5F Byte 24, enable Bit 6: vza - activate Byte 24, Bit 7: psd - deactivate Adaptations for 5F Car_Function Adaptations_Gen2_menu_display_road_sign_identification - activate Car_Function Adaptations_Gen2_menu_display_road_sign_identification_over_threshhold_high - activate Car_Function Adaptations_Gen2_menu_display_road_sign_identification_standstill - activate Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 - activate Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus – Extended data bus Module A5 Frt Sens. Drv Assist Coding Byte 58 bit 6-7: 80 VZE traffic sign detection, hidden Module 17 Instruments Byte 14 bit 06: traffic_sign_detection, check this Module 82: Head up display Byte 00 bit 00: Traffic sign detection, available
Hi Singh, I was able to follow each mod steps, however on 5F the Bit 7 (PSD) is not in there… just go to Bit 6. Any thoughts? Tks!!
Module 5F
Adaptations for 5F
Coding
Hi Singh,
CR 2022 R Line
I’m able to follow each step of the mods, however on the 5F , Byte 24 Bit 7 it’s not in there… my one just show till Bit 6. Any thoughts about it?
tks, Gabriel
Discussion starter · #384 ·
Hi mate, this post is getting mixed up a bit now, originally this post is for 7P but folks with CR and other models have been keen, but the steps are different.
In your case, assuming you have 7P Touareg just follow the instructions right at the top, dont worry about psd
Discussion starter · #385 ·
Hi Singh,
CR 2022 R Line
tks, Gabriel
I am assuming you are using vcds and latest version?
Seems like in the latest version the label file has been stripped of this particular label for the bit.
But not to worry, just do it manually, go to byte 24 and change the bit 6 to a 1 instead of a 0.
Looking at the bits there first but from the right going to left
Hi mate, this post is getting mixed up a bit now, originally this post is for 7P but folks with CR and other models have been keen, but the steps are different. In your case, assuming you have 7P Touareg just follow the instructions right at the top, dont worry about psd
Tks for your answer Singh, my one is 2022 (2023) R line, so I’m assuming it is the CR model, so the PDS should be there… I did all the mods (apart the PSD) and the DRS is not working, all menus it’s showing on Radio but definitely not working.
Hi Singh, I’m sorry don’t know why the forum make my post in duplicity.
So the Byte24 bit 6 it is in there and I was able to change it.
The Byte24 bit 7 it’s not in there…
I was able to change everything apart this one which is the bloody PSD and the DRS is not working… I’m gonna plug again and make a photo to show what is happening…not sure if someone has experienced the same issue.
Thanks.
Gabriel
Discussion starter · #388 ·
Thanks.
Gabriel
It's the latest version of vcds, it's not showing bit 7 that it used to before.
Just change it manually, from 1 to 0....it's bit 7, so count from right, first bit is 0 then 1, 2,3,....your seventh bit will be 1, change it to 0, save and exit
Hi Singh,
Don't you know, maybe i also need to change those two bits in 5F module (24 byte, bit 6 and 7) to make sing recognition work without maps? My variant is Touareg 7P. Regarding my previous post here: https://www.clubtouareg.com/threads/dynamic-road-sign-assist-enabled-touareg-7p.268177/post-2195689
Discussion starter · #390 ·
Hi Singh,
Sorry mate, missed your post.
You have a 7P so you don't have the psd issues that CR owners have to work around with, so don't worry about that
Can you confirm you have carried out the following changes to the modules and in green screen menu
  • 17 Instruments, Long Coding, Byte 05, Bit 2 on
  • 8E Image Processing, Long Coding, Byte 02, Bit 0 on
  • MMI Hidden Menu: car/cardevicelist, VZE on
  • MMI Hidden Menu: car/carmenuoperation, VZE => 5
Can you confirm where in the world are you? It's likely the geographical restriction is preventing this for you, sorry no workaround that as far as I know
These options already set:
For options:
I am not able to check because i have no green menu. Is it possible to set those values via long coding? Which bytes are responsible for it?
Discussion starter · #392 · (Edited)
For options:
Google or search here on this forum re how to enable and access the green screen menu, once enabled carry out the last two changes.
Country restrictions still may apply so you may not have the tsr function depending which country you are in
Great, Singh you’re definitely the best helper here. I’ll do it and come back with the results.
tks, Gabriel
Hi Steve -- What module am I looking for -- I dont have lane assist it looks like the one below - Thanks
Sorry Ian,
we were on the road back to Perth from Brizzy when you posted that.
I was led to believe the critical module is 8E (refer to Singh's post #16 in this thread).
There are some posts leading up to #97, where Singh declares that there has been no success applying these changes to cameras fitted to pre-facelift 7P cars (that change occurred circa 2015).
So that seems to be the application cut-off (as VW seemed to change the camera specs - amongst a lot of other things in the series post 2015).
owns 2015 Volkswagen Touareg R Line
