So I replaced the 4 struts on my 06 V10 (the springs on both large struts were completely broken). I went into the car wash today and had a huge amount of water come in and gushed down both D pillars. The car is new to me, so I don't know if it had leaks prior. The seals on both hatch covers were crumbling and destroyed in the process of my "repair", and I had read it could cause a leak, but I wasn't expecting THAT much water inside the roof there. I picked up some loctite marine sealant on the way home. Cleaned up the panels and reinstalled with a big bead of sealant. That's should be well and good, but my question is, if I have that much water entering that area of the roof should I be investigating where it came from? I cleaned out both drainage points by the hatch hinges. There was debris but they weren't fully clogged. I didn't find any excess water up there when I brought it home and removed the panels, it seems like the drains were doing their jobs (and a lot of water took a quicker escape through the plastic panel covers). My next guess is the roof rails. Should I pull them off and reseal? or is it normal to have that much water in there doing a car wash?
For those that come after me, heed my advice. Make sure you seal those panels back well when you do this diy.
