1 - 7 of 7 Posts
to turn off the auto locking doors all you have to do is go into the display in the middle consile and turn it off your self trough the computer just click on the lock button in the display and you will see the check mark leave then you will know it's off.
That is supposed to work. (While not moving, go to COMFORT, DOORS, and uncheck AUTO-LOCK) If, however you reset them and the settings slip off, you can go to the dealer and they can perform a reset with the VAG-COM. I've had that problem a couple of times.
SUVW: convenience settings should not be slipping off. I'm supposed to be getting a new "Convenience Control Unit" because they keep slipping off mine, too. It's been promised for a month and a half now (and I've been complaining about it for 2 months), so we'll see if it does anything when it finally comes in.
Of course it shouldn't "slip"... and the tires shouldn't be shot after 25k, and the TPM shouldn't have had to be replaced twice.... etc etc etc.
1 - 7 of 7 Posts
