Thanks all, keep it coming. You probably have heaps of little tips about things I wouldn't even have thought about. There are some interesting new things and confirmation of a few others so far. The van we are currently thinking of as our most likely choice is the Kimberley Kruiser. Air suspension (with shocks), electric over hydraulic disc brakes, tropical roof, heaps of solar, 2 kitchens, full ensuite, around 300l fresh water + gray water storage, Inverter, diesel hotplate and heating, double glazed windows, insulated etc. but still checking out what else is around. The construction of the Free Spirit vans looks very good as well. John
Giday John,
Sorry about the delay in getting back to you. The Van's all clean and the Treg gets a spring clean on Tuesday hopefully.
Bugger about your work schedule as we found the caravan shows of some value. After hiring a camper trailer last year for a trip we started looking around pretty seriously at camper trailers and had narrowed down a couple of contenders around the 50 to 60 K range. After further thought we decided it would be likely that we would get over doing the 'origami thing' setting up and packing up the camper trailer and decided to look a little more at full size caravans.
The caravans we really liked included: Kedron, Trakmaster, Bushtracker and Evernew.
Unfortunately all of these were out of our price range, so we had to start to compromise.
After considering that most of the trips we are likely to do, while I am still working would be mainly on sealed roads we decided we didn't need a true 'off road' Van. We saw the Lotus vans (amongst others) early on while looking around and found we kept coming back to Lotus for various reasons.
The Treg Muster we just got back from was certainly a good work out for it. Approximately 1800 Km of corrugated roads and a cupboard door came off (mainly as a result of heavy items on the shelf banging on it) and the microwave came loose. Seafarer28 told me just this morning that a guy he was speaking to the other day with a Trakmaster had their microwave come right out.
Anyway, I would be the first to agree that the Freelander is not an offroad van, however with the control rider suspension on ours, I reckon it did a pretty good job.
The major issue we also had to keep in mind is that the newer Tregs have a max towball limit of 280 Kgs. Your V10, I believe has a 350 Kg tow ball limit.
We saw the Kimberley Karavan at the Rosehill caravan show when it first came out and thought it looked an interesting concept and comes from good genes. I just did a quick search on caravan camping sales and saw this one:
http://www.caravancampingsales.com....5572 4294965436 4294887932&silo=1701&seot=1&__Nne=15&trecs=4&__sid=148BE7DDE2FE
This one certainly seems well optioned. One thing that stands out to me with this particular Karavan is that is has a maximum payload of 500 Kgs. By the time you subtract the weight of a couple of 9kg gas bottles AND the total water you will be carrying there isn't much left for all your other stuff. I see Dubby suggested a minimum water load of 350 Kgs. If this Van could carry that much water, you would be left with an allowance of 130 Kg for EVERYTHING ELSE.
You will find this payload issue will come up all the time as you narrow down your choices. Many Van and Car combos on the road today are simply overweight in some form or another.
Further info here on weights:
http://www.lets-getaway.com/caravan-complianceplates.htm
We got our Van weighed for the first time as we left Sydney on the recent muster. It was chockers with a full fridge, clothes, generator, and full water tanks (190 litres) and it weighed 3350 Kg. The upgraded suspension on our Van gives us a 850 Kg payload.
Given the type of self contained travelling you are planning, the only real limit to your travels is water. I do like Steve_L's suggestion re the 200 litre bladders. With a couple of AGM Batteries and a couple of solar panels on the roof you will have pretty much uninterrupted power.
I second the motion re full ensuites and a washing machine. There is nothing quite like spending the day on dusty roads and jumping under a hot shower before a beer around the campfire. Our washing machine is typical of those in a Vans. About 2.5 Kg load from memory but we use it a lot when water is available (it does use heaps of water).
You will soon find, I'm sure like we did that purchasing a caravan will likely involve compromises in some form. The payload matter is typical. Just saw in a caravan mag the other day a new caravan retailing for 200K! I really wonder whether it offers 120K more value than our Van but I guess time will tell.
I see from your profile that you're around the Sunshine Coast. You should contact Dubby and check out his new Van when he gets back home (around Feb next year I think). I was very impressed with it and reckon it would be worth your while having a look.
Hope this is of some use.
Regards
Gary
Here's some links that may be of interest:
http://caravanersforum.com
http://www.towingguide.com
www.exploroz.com
http://www.goseeaustralia.com.au
http://www.stonestomper.com.au
https://www.whitworths.com.au/main_itemdetail.asp?cat=123&item=35794
http://www.fridge-and-solar.net/info.htm
https://www.myvast.com.au
http://www.redarc.com.au/products/product/tow-pro/
http://www.dutch-oven-camping.com
http://ampfibian.com.au
http://www.coastrv.com.au
http://www.ciavic.com.au/
http://www.cciansw.com.au
http://www.australiasomuchtosee.com
http://stores.ebay.com.au/autoelecau?_trksid=p4340.l2563
http://thegreynomads.com.au
http://caravanningnews.com
http://caravansplus.com.au/
http://www.bestwaterfilters.com.au
http://www.alkoesc.com.au
http://farcanal.blogspot.com.au
http://www.supercheapauto.com.au/on...oducts/Explore-Tandem-axle-Levelling-Ramps.aspx?pid=326651&menuFrom=90307#Cross
