Sorry for taking so long to update but I've had a busy week. The repair was a success!! Fan blower now works like new with plenty of power and no noise.
There is already a 'how to' on removing the blower motor so I won't go into that. The following pics are from the motor being removed and on the bench.
The brushes in these motors are seated in a plastic holder that is retained by a small spring. I made the mistake of removing the holder and the spring which turned into an hour if trying to replace it!!! Do not remove the plastic holder, hold it up with a screwdriver and cut the copper wired going to the brush and then remove the brush itself.
The picture shows the plastic holder and the small spring.
When you have removed the old brush you will need it as a template for the new one as they need some trimming to make them fit in the plastic holder.
As you can see, there are two groves to the side of the old brush.
I used the old one as a template and trimmed the new one with a stanley (hobby) knife. It's very easy to trim as the brush is made of carbon, the same material as a pencil lead.
The new brush is also slightly too long (about 5 mm) so I sanded the end with a sheet of 120 grit sandpaper.
When this is done the hard part starts. Trying to fish the new brush into the holder through the fan cage. This took me almost an hour to do both. Once in, I soldered the ends to the end of the copper coil as below.
And that's the hard part over. Now to reassemble the motor into its plastic cover/mount. A small tip- use washing up liquid on the rubber mounts to make them easier to slide into their holes.
When everything is back together make sure all four rubber mounts are seated properly, the plug from the motor is clipped into the cover and your soldered wires are secure. Also make sure they brushes are touching the armatures because if they are slightly too long they will sit on the plate beside the hole where the brushes go into to touch the armature. (The only way I could explain this as its too small and awkward to take a pic)
Put the unit back into the car with 7 5.5mm screws and plug the motor in. And hey presto- working motor! (well it was for me). This job cost ÂŁ5 and about 1-2 hours work and saved me almost ÂŁ200!
Any questions don't hesitate to ask.
