The dealership is telling me that they have to reprogram the vehicle when they replace the battery.
Matt
Matt
That seems like a quick degrade for an '06. I routinely work my 100W Ham Radio rig of the main battery for an hour or so at a time; and work on the car for hours at a time with the interior lights on. Battery is still holding the requisite 13.8 v at start.If it makes anyone feel better, my 06 battery is getting ready to take a dump. It died at the tire shop while I was having snow tires put on, all because the left the doors open for a few minutes. Starting voltage is around 12V, which is low. Charge voltage is nominal at 14-ish volts. Oh well, I'll have the dealer replace under warranty.
I'm sure the cold doesn't help, but the battery is not holding the charge after a drive. Residual voltage after a drive is about 13.8V, but a few hours later it is back to around 12V.That seems like a quick degrade for an '06.
Can you help me locate the second battery in my V10 with air? According to the owners manual it indicates the second battery is in the trunk with the spare tire, but that is where my air tank is:confused2:A touaregs with air don't have a second battery, just the V-10. I don't beleive there is a switch between the two. I think they operate together for increase capacity.
Didn't think of that! ](*,)ThanksIt's UNDER the spare tire. Pull the tire out to get too it.
I had planned to replace the battery myself - but then realized how much was involved, so I took it to the dealership. I had picked up the proper battery for it from Napa ($117 if I remember right). When I got to the dealership they checked for any open recalls. Sure enough, a battery cable replacement recall had not been done yet. I therefore, was able to get the battery replacement done as part of the recall. They also reprogrammed/updated the three (I didn't know it had 3) computers on the Treg. Volt gauge has been reading 14V ever since.OK How do I edit a post? I wanted to add some info.
They had told me that the car would be in limp mode if they didn't reprogram it.
Matt
EDIT: Well I seem to be able to edit a second post, just not the first.
I can not seem to locate the battery info. I do need to find the paper work for it though. Maybe I put in in the folder for one of the other cars. :drunk: However, Napa was able to look it up without any difficulty.Good post, and a reminder to many owners that may not have known about the battery cable TSB or have had it performed.
Also, do you have a part number for the battery that you originally got at Napa?
