My wife's touareg won't start. It will crank but not start. Using VCDS I am not seeing any rpm signal during cranking. Is this normal? Should I see RPM and engine speed during cranking?
There were multiple cylinder misfire codes. It did run rough earlier in this week but then cleared up. Check engine light is always on due to a slow coolant temp sensor.
I appear to have fuel pressure, and can cycle the fuel pump on using VCDS.
Should I see crank and RPM signal/speed during cranking?
