41 - 60 of 121 Posts
ummmm, strange, following the exact same procedure and it just hangs. is there a reset feature for the software update...??
I did mine with the air con and lights turned off. I notice from the photo that your air is on hence blower running even though engine is off. Perhaps the thing is clever enough to monitor battery drain and know it can't complete the update before low battery. I am assuming your engine is not running.
Wayne
Did the update today on my 2019 launch edition with the latest updates and all went fine.
This was the first time I've done it and reading the previous posts I can see how there can be some confusion around what to do.
The VW instructions are actually incorrect. They refer to a sub-menu that does not existing in the Settings menu. There is no version information menu in the main settings menu. I also noticed that the latest update places the 2 folders "Data" and "Meta" in another folder called "P0443..." which the previous update did not.
So here's my tips for a trouble free update for cars with the discover premium (big screen) systems.
1) Use a class 10 SD card (NOT USB) of at least 32GB in size - I bought a 32GB Sandisk micro SD card with adapter from Officeworks for about $8.
2) Format the card in NTFS not FAT32, a quick format is fine. Don't use a Mac, use a PC with Win 7 or higher.
3) Download (takes a while) and extract the Data and Meta directories to the root directory of the SD card. Make sure there's nothing else on the card - I suspect the issues some people are getting with the update being slow to start are to do with the Data and Meta Directories being located in a sub-directory or there are other hidden files/folders on the SD card. SD card manufacturers love putting bloatware on their card, my Sandisk came with several other files and hidden folders, just format it straight away and get rid of it all. Again make sure the Data and Meta directories are in the root (top level) directory and there are no other file/folders.
4) Switch on the ignition, no need to start the engine, turn off the lights and A/C and to be safe hook up a battery charger to the jump points under the bonnet on the driver's side.
5) Insert the SD card into the slot in the glove box - the screen will display a message that and update is available and then will disappear - this is normal. The update does NOT start automatically.
6) Now press the "Menu" button on the touchscreen, then press "Settings" and then press "system information" - this is where the manual is wrong. It says to press "version information" but that menu is actually under the Navigation settings menu, it does not exist in this menu. I got confused by this also the first time.
7) Press "update software". Now a screen will pop up telling you there's no update available, but then another little screen will pop up saying "checking for updates". On my car it only took about 30 seconds to "find" the update on the SD card and commence the update progress. Some people are reporting this takes up to 5 minutes, but I suspect it's because the SD card is not set up correctly (freshly formatted, and the Data and Meta directories in the root directory-refer to point 3).
8) The update itself takes around 50 minutes, and it will appear that there is no progress for quite a while before it ticks over to 1%, but once it get's going it's fairly steady progress, albeit slowly.
9) At the end you'll get a message that the update is completed, switch off the car and remove the SD card. For good measure do a "reboot" ie lock and unlock.
The update is quite good as I live in the North of Perth and there's constant roadworks here. This brings the maps almost up to today's accuracy, although I don't normally use the built in maps as the voice interface is the worst I've ever come across, even worse than my old 7Pwhich was fairly clunky, I normally use google maps on my iPhone through carplay.
Have fun!
where are you getting "set-up" from, i can't see such sub-menu, only system information then "update software"
Anyway, re-format number (lost count)....
Sorry...Settings (see picture). then scroll down to system information. original post updated
Maybe try another SD card, they're only a few dollars from officeworks.
My new SD card was actually formatted as FAT32 out of the box so I had to re-format it anyhow to NTFS before I began.
241358
ok thanks -its really strange as the last one i did worked flawlessly and this one doesn't seem to do its thing. i have reformatted to NTFS multiple times. anyway i will try another SD card!
sounds like this is a good excuse for another Perth catch up? Some map updating etc etc
I think this update is more than just maps. I have my car setup so the when reverse is selected the passenger side mirror tilts down so you can see the back wheel vs gutter. This stopped working post update and I had to set it up again.
hmm ok my reverse camera went completely haywire after this also (black screen), but after a couple of re-starts it seems to have settled down now.
However my car had just been serviced and I was told a "software update" was installed to fix some random stuff that was happening (car forgetting driver settings and tuning random radio stations). It's a September 2019 build.
My reverse mirror tilt has never worked, I've toggled the setting several times, I forgot to mention it when I just had the car serviced. I'll keep playing.
Dont forget the hard drive needs to be NTFS if you are downloading to there first.
yep checked that and hard drive is NTFS. Maybe the SD card has become corrupted. I am yet to try another card. It’s just all odd as it worked first time updating. Now it just hangs until the car switches off on its own.
I used this from Officeworks. It came with an adapter for the full size slot.
If you really get stuck PM me and I'll give you a hand.
Thank you - I will get another card and give it a crack and if no luck the I will send out an SOS. Lol.
Hi mate when did you do your previous map update. I’m thinking those of us that did it recently 3 ish months ago probably are trying to load the same files. Maybe other countries had updates.
The map version in my car is showing 2021. There's a new update that just came out, so perhaps re-visit the site and check the filename against what you already have. Unfortunately I've deleted the .zip file and just have the SD card left and the files are dated the day I extracted them so I can't check but I'm sure the folders were dated September or October.
