Looking for someone whos changed the fog light housing on a 2014 r line...i havent tried yet as i just bought it but i read that it wont come out the front like a standard touareg..is this correct? anyone got some advice before i start tackling it
have a read of this thread and see if it helps LED Fog lights Touareg 7PLooking for someone whos changed the fog light housing on a 2014 r line...i havent tried yet as i just bought it but i read that it wont come out the front like a standard touareg..is this correct? anyone got some advice before i start tackling it
thanks but wasnt any help...all the talk was mostly 2015 facelift pictures and led bulb talk.have a read of this thread and see if it helps LED Fog lights Touareg 7P
Maybe like in the video below? Not sure if the "R" line is the same as far as panels as a standard 2014. Hope it helps.Looking for someone whos changed the fog light housing on a 2014 r line...i havent tried yet as i just bought it but i read that it wont come out the front like a standard touareg..is this correct? anyone got some advice before i start tackling it
no thats the point of the post the bumpers are not the sameMaybe like in the video below? Not sure if the "R" line is the same as far as panels as a standard 2014. Hope it helps.
yah i can see that but ive read the housing still does not come out that holeMy 2013 R line fog light and radar unit panels unclip from the inner edge
cheers
Rohan
Does it look like the pic below?no thats the point of the post the bumpers are not the same
Could you post a picture of the cover you're talking about for the OP so they know. Thanks.Its a 1 minute job to unclip the cover on the front of the bumper. You then should be able to see if the fog light can be pulled out or whether the whole bumper needs to come off.
i was looking for actual experience so i dont need to pry on frozen plastic if there is no pointIts a 1 minute job to unclip the cover on the front of the bumper. You then should be able to see if the fog light can be pulled out or whether the whole bumper needs to come off.
I don't know if you squared this away yet or not but another member just posted up the solution.Looking for someone whos changed the fog light housing on a 2014 r line...i havent tried yet as i just bought it but i read that it wont come out the front like a standard touareg..is this correct? anyone got some advice before i start tackling it
2015 is entire different front end....not the same at allI don't know if you squared this away yet or not but another member just posted up the solution.
Check out post # 14 of the thread in the link below.
Link >>> 2014 Touareg fog light assembly replacement
Damn I missed where he wrote 2015.2015 is entire different front end....not the same at all
