New tdi owner here. Thanks for the add to the forum. I've been following for a while. I am not new to touaregs but this is my first tdi. All tips, wisdom, and advice is greatly appreciated.
I believe a while back I had come across a post mentioning a gentleman who had swapped an ecu from a touareg that had not recieved the emissions recall fix yet, but I cant find it anymore.
I have a 2012 Volkswagen touareg tdi with only 32,xxx miles with the fix already completed. I was wondering if it were possible to get prefix results simply by swapping ECU's with an original one from a different car that hadn't had the fix done yet?
I was hoping to learn more about this. Is it basically plug and play or does something need to be done with vcds? Would this create a separate issue with the tcu? Would a replacement ecu need to be specific with the exact same options or could this be modified with vcds? Do I need to be cautious of the ecu donor vehicle milage? Anything else to look out for? I do have a Ross tech vcds cable.
Thanks for your time. My apologies for the multiple questions.
