21 - 33 of 33 Posts
I put a set of Hoen 55W Xenonmatch bulbs in my Avant, they match very well. $30, maybe not the cheapest solution.
Hoen
LED in driving lights
I installed a set of LED 9006 in my T3 and they work out pretty well.
9006 6W High Power LED Fog Bulbs (6000K White) Ultra High Output from ebay - special price was cheap like $17 for the pair so they were worth a try I thought.
I have installed HID bulbs in my fog lamps, but chose to go for 3000 K temp ( yellow) as they work much better in fog than bright white does. May not look that sexy, but as far as being able to see safely ahead, you should try them!
Stu..
I have installed HID bulbs in my fog lamps, but chose to go for 3000 K temp ( yellow) as they work much better in fog than bright white does. May not look that sexy, but as far as being able to see safely ahead, you should try them! Stu..
I did the same thing and agree that it's more about function than looks.
The PIAA HB4 (9005/9006) bulbs do indeed fit.
I changed mine out for the PIAA plasma ion fog bulbs since the winter is rapidly approaching.
21 - 33 of 33 Posts
