41 - 53 of 53 Posts
On the air...95% of people didn't pay for the $3000 "fancy suspension". No surprise to me that VW said its obviously a feature not in demand.
You're probably right and likewise 95% of people probably never go offroad either. I [we on this forum for the most part] unfortunately happen to be in the 5% that do.
VW moved upmarket with the Phaeton and Touareg, and now they are repositioning downmarket...I'm sure the studies they have done will show that those who can afford a full jam V8 or V10 Touareg will likely move up to a Cayenne if they really want big power and A/S. The V6 TDI is also coming in the Cayenne and I have no doubt that Porsche is more than happy to take your money on that option...I know I have no interest in either a V6 gas or V6 TDI (not enough power), so my options come replacement time are limited to a Cayenne or something different.
I would think that V6 TDI would get you going just as well as your V8 perhaps a little better [have you driven one Nick?], you just wouldn't quite have the top end. Unfortunately, the Cayenne is something I've always considered fugly and the new spy pics I'm seeing are making that opinion worse not better.
We'll either take the Treg TDI without air [doubtful] or keep driving the XC90 another year at least to see how badly they butcher the 2011.
Or maybe we'll get lucky and this is just another off again on again rumour thing and air we'll be available on special order ...:dance:
I did drive it extensively and it just doesn't do it for me...its better than the V6 gas but it doesn't have anywhere near the punch off the line or the acceleration of my V8.
X2. I drove both and the V6TDi is nice but it's a step below the V8 in terms of power (towing might be a different story.) I also drove the new Q7TDI (even took it home for the night) and even though it the same motor and same specs i found it to be far more responsive and it felt more powerful... i was very impressed with the Q7 TDI's power and driveability... the Touareg V6Tdi was "good"... but it felt like there was a lot more turbo lag... while there was almost none with the Q7.
The q7tdi can't be ordered with air from what the online build guide allows - have you by chance asked that directly to anyone? aside from no low range and locker, at least the air lift was cool for the q going on rougher gravel roads to trail heads for hiking or the like.
There are no 09 Q7 TDIs with air (at least any that are not pre-sold.) For 2010, YES.. you can order air susp, it is a stand alone option and it's on the order guide... i put together an order and wrote a check.. then found out i couldn't order an S-Line TDI in 2010 so we walked.
Bluetooth is now standard on all 2010 models. It's the 9W3 option aka the "Skoda" unit. It has Bluetooth audio streaming. That means the US market will be getting the right side steering wheel stalk that has the phone button.
The 2009 TDi i drove the other day had factory bluetooth with the BT buttons on the right side steering wheel stalk. I think i am going to order up the parts and add factory BT to my RNS510 in my 08.
The part number for the RNS-510 is 7L6 035 684. The bluetooth p/n is 1Z0 035 729 A but you can also use 1Z0 035 729 D. 1Z0 035 729 D has bluetooth audio. The phone button is part number 7L6 959 538 E 3X1. Your dealer will have to code the bluetooth module since VCDS has outdated label files.
Thanks! Any idea on the pricing i should expect on the BT module? And i am guessing i should go with the "D" model if i can find it?
The A module is whats currently in the ETKA. I think you can use the D module. You can get either one on ebay. There is this really good Polish seller that sells them at a good price. You'll still need a new right side steering wheel module with the phone button.
The RNS-510 part number is now 7L6 035 684 A which has a new firmware. The Mute button is now the Phone button. If you have a 9W3 kit installed on a non A model the Mute button becomes the phone button. You can also get a firmware update disc which updates it to the A firmware.
VW RNS510 MFD3 BLUETOOTH KIT GOLF MK6 CC MFD RNS -VER D:eBay Motors (item 190307971728 end time Jun-15-09 01:13:07 PDT)
Here is the D kit. Just make sure your dealer codes this and the steering module. VCDS can code the the stalk but not the bluetooth kit. He also sells the A module which also has to be coded. Same module really but no Bluetooth Audio.
All 2009 Touareg's with the RNS-510 and the 9W3 option use 1Z0 035 729 A. Might want to use that since it's guaranteed compatible. Not sure if the D is compatible. The ETKA says the A part is the one to get. It will require the dealer to code it since VCDS is wrong in that regards. I think the D might just work.
And here are the scan and adaptation channels from the Touareg. One thing I noticed in the Touareg is that the BAP protocol WAS NOT checked despite it having a multi-color DIS display.
VIN: WVGFM77L29D035020 Mileage: 80km/49miles
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 C HW: 7L0 909 135 C
Component: Kessy 6850
Revision: 00H22071 Serial number: VWX3Z0H2826722
Coding: 0000232
Shop #: WSC 31414 790 00001
Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2004
Revision: -0004--- Serial number: --------------
Coding: 230008002F00BC000000000000000000
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
Address 17: Instruments Labels: 7L6-920-xxx-17-7L6.lbl
Part No SW: 7L6 920 990 P HW: 7L6 920 990 P
Component: J285 KOMBI-INST. 9733
Revision: KHH06V42
Coding: 0007201
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7L6 920 990 P
Component: J533 GW-K-CAN TP20 9733
Coding: 77E2F7DBCB846002
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 7L6 035 684 B HW: 7L6 035 684 B
Component: RNS-MID H01 0322
Revision: AB001001 Serial number: VWZ6Z7J6025033
Coding: 000100000100002600
Address 46: Central Conv. Labels: None
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6304
Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6304
Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 C HW: 7L6 035 456 C
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000212446
Shop #: WSC 00000 000 00000
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
Address 68: Wiper Electr. Labels: None
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
Part No: 1K0 955 559 AH
Component: RLS 030209 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: Redir Fail!
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0050
Revision: 4A007002 Serial number: 00000116720000
Coding: 0016386
Address 6C: Back-up Cam. Labels: 7L6-907-441.lbl
Part No SW: 7L6 907 441 B HW: 7L6 907 441 B
Component: J772__Rearview 0033
Revision: 00H13000 Serial number: PA8 J910087
Coding: 0110001
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------043590
Coding: 0122110
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000107862
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 A HW: 1Z0 035 729 A
Component: FSE_2P8x H34 0150
Revision: 00000000 Serial number: 00000005015376
Coding: 0012077
End ---------------------------------------------------------------------
Here are the adaptation channels:
125 - NA
126 - NA
127 - NA
128 - 0
129 - 6
130 - 2
131 - 0
132 - NA
133 - 1
134 - 0
135 - 0
136 - 85
137 - 0
138 - NA
139 - NA
140 - 0
141 - 0
142 - 1
143 - NA
144 - NA
145 - NA
This is from a 09 Touareg with the 9W3 module. This particular one has the Color MFD display. BAP isn't enabled on this module. Hope this helps.
41 - 53 of 53 Posts
