Does anyone know of a source for dpf delete pipe for the 3.0 tdi?
Yes, Les's set up is 3 inch. It eventually reduces down to 2.5 inch so you can couple to the pipe coming out of the stock muffler.It is my understanding that Les (dieseldubs/GDM) uses a 3" pipe, not 2.5". I'm having the delete done this week, so I'll report back with my thoughts/opinions after it is all said and done.
German Diesel Performance which used to be DieselDubs. The owner is Les. The actual tuner is Malone.So who makes a tuner to do a full delete? It's probably in this thread but it's a long thread. Lol
Mick.....that's not good. Don't get why WOT would put it into limp mode. I have never done WOT with my Treg. I guess I should try it and see what happens. Have never gone into limp mode since the tune. My tuner never told me that Malone said that limp mode was possible under certain circumstances.Hi, had DPF delete and Malone stage 2 tune end of May. All good for @ 600km and then would go into limp mode under sustained WOT while passing semis. Would also go into limp mode under low load but steady throttle.
Keep in mind, I was warned by Malone this may occur.
Had ECM reflashed and no more limp mode. But. Now the engine does a cycling of on/off power under sustained high load.
As soon as I can, I will be doing some testing to narrow down the root cause.
I will keep you all posted.
Mick
Mick
Hi, right now I only have the kit pipe with a resonator and the stock suitcase muffler. I do hear more exhaust and turbo sounds. I can hear a drone at 120 kph and may add a drone tube like Zagg did.Mick, what did you use for exhaust and how is the in cab noise?
