18" Wheels to Fit T2 / 255/55/18
6.6K views 5 replies 6 participants last post by  goudh
Hello all: I'm an absolute tire dummy -- especially regarding my 09 T2. I've decided on the Grabber AT2 255/55/18, but I'm not clear on whether this size will allow for proper clearance for the brakes etc. Also, I'm not clear on the proper "lug pattern" for fitment on my 09 T2. (I could go 255/60/18 if that is considered a better choice for off-road.)
My goal is to acquire a set of AT tires and off road style rims that will fit my T2 without concern for rubbing the wheel wells and all that rot. Can anyone please give me some guidance on the proper type wheel / pattern I need for correct fit?
Also, any recommendations for a good value on AT Rims would be very helpful. I'm looking on Amazon.
Thanks in advance!
hi, what size rimes do you have on your touareg? for off roading best size is 17'' or 18'', porsonally me i would go with 18 as you have more tire choice :) . also are you going to buy wheels and tires and have off road setup or you are going to use them for every day driving? i think its better to stick to OEM wheels as they are very good quality as touareg is a very heavy SUV and you need reliable wheels to go off road. specs for the OEM 18'' wheels are 18'' x 8'', bolt pattern is 130X5 center bore is 71.6 mm and wheel offset is 57mm . maximum tire you can fit on these wheels are 285/60/18'' and you need 5mm spacer in front. if you do not want huge tires but good size for off road you can go with 265/60/18 and you will not need any modifications at all :) if you will have any questions post then here. and one more advice :) before you will start a new thread you can use search function and find huge amount of info about most things you will need regarding your touareg :) kind regards, Nikoloz :)
Drifter - 255/55R18's will be no problem. I ran 265/60R18's for around 50K klms with no size problems. Suggest 255/55 or 255/60 in 18's will be fine.
Bigger ain't necessarily better - especially with only 6 cyl. Dub
