I've started compiling a list of the biggest tyres for each wheel size, that can be fited to the T1 and T2 Touaregs.
We often see the question: "What is the biggest/widest tyre I can fit to this wheel?", so the idea is to get as much info as possible of actual fitments by members and to update the list on a regular basis.
If your setup is pushing the limits of what's possible, please post here, the following info:
If you have any comments/problems/concerns, please add it as well.
Lets see how many responses we get. If we get enough input, I'll make this a sticky for quick reference for all members.
Keep in mind that there could be two parameters that determine the maximum tyre size; the overall diameter, as well as the width. You might find that going to a 32" tyre means you can only go up to 265 width, for example, but you can fit a 295 wide tyre if you decrease the diameter, so we're interested in both cases.
The list also contains the OE sizes as well as recommended off-road tyre sizes, for reference. Currently it only shows up to 21" wheels, as this is the biggest OE size, but I would like to extend it to the 22" and 23" sizes as well.
The more info we get together, the better. So lets pull together and see what we can come up with.
- Tyre size eg. 265/65R17
- Tyre brand and model/type eg. Bridgestone Dueler A/T D694
- Wheel size eg. 7.5Jx17
- Offset eg. ET55
