That's right. I've gone 150,000 miles on my original timing belt and water pump on my '04 V8. VW should pay me to replace it just so they can analyze it (the timing belt that is). It is a bit loose with a good bit of play but never caused a problem. The decision is made and I am changing it myself. I could use some input aside from the other threads. You see, I REALLY need to keep cost to an absolute minimum. I only need to get another year and a half/40,000 miles out of this one. There is no oily spots or leaky spots that would necessitate crank or cam seals. I AM of the opinion to go ahead and do the water pump while the front clip is off even though I have never had cooling issues.
- How necessary is it to replace the tensioners and idlers (I had an '88 Vette with 140,000 and never replaced those for the serpentine pulley)?
- How about the tensioner damper?
- Is the water pump the pulley right above the crank pulley? Do the cam covers have to come off to get to it?
- Can I just change the actual belt and water pump and be done with it?
- Does the Bentley manual cover this?
