261 - 280 of 1,783 Posts
It doesn't seem to read the same as the US modules for some reason, just says "0000":
Address 02: Auto Trans Labels:. 0C8-927-750.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 AK
Component: 34LJ1Z02.MOT 0000
Revision: 00H01000 Serial number:
Coding: 0045416
Shop #: WSC 02731 780 00200
VCID: 75B71C6FF9C17E6F51E-8021
A clean 2014 LUX has the following.
Component: AL1000 AISIN 002 2470 ..... note the 2470 my 2014 fix has 3376
From here:
2014 VW Touareg Lux, 3.0 TDI CNRA
Discussion starter · #265 ·
Trick question
Who recognizes this part number?
0C8 927 749 FC
Monday,13,August,2018,13:39:13:30355
VCDS Version: Release 18.2.1 (x64)
Control Module Part Number: 0C8 927 749 FC
Component and/or Version: AL1000 AISIN 002 2486
Software Coding: 00B168
Work Shop Code: WSC 31414
VCID: 7AFB4BA0FDA9CA9469-802E
Advanced Identification/FAZIT
Serial number:
Identification: AW7-000
Date: 13.01.14
Manufacturer number: 0003
Test stand number: 0153
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 01.01.00
Misc.
Hardware number: 0C8 927 749 FC
Workshop System Name: J217
ASAM Dataset: EV_TCMAL991031
ASAM Dataset Revision: 002115
VCDS Info:
Labels: None
ROD: EV_TCMAL991031_002.rod
Trick question
0C8 927 749 FC
Serial number:
Date: 13.01.14
Flash Status
Misc.
VCDS Info:
Labels: None
looks like from a Google search, that that part number is out of a 2014 Pepper Cayenne. Can't tell you if it's a gasser or TDI flash on the firmware, though.
Discussion starter · #267 ·
Correct sir! :wink2:
This is from a TDi Cayenne. VCDS can read info, clear codes, re-code etc...
Probably will also work for the ECU as well on the Cayennes and maybe even some of the power transmission safety systems like ABS, etc...
Very happy with the TCM update/restore from Yrktreg. Communications was excellent and the entire process went smoothly. Initial impressions; quicker/lower rpm shifts around town, more engine breaking then before but not as much as my 2011. Expect it will improve my around town mpg, TBD. Much closer to the driving experience of the 2011. Pre and post VCDS scans are exactly the same. I’d recommend this to anyone thinking about it and wouldn’t hesitate to do business with Joe again.
Discussion starter · #272 ·
Thank you sir, it was great working with you...
I also did the TCM update with Joe. The transaction was perfect and Joe is a pleasure to work with. The Touareg shifts the way it did before the TDI update. I would not hesitate to go to Joe for anything else in the future.
Could someone please provide details of how to contact Joe, or find someone who is capable of doing this mode. Since the TDI mod, not happy with the high RPM gear change when cold, as well the loss of engine breaking is sad, would love to get the setup returned to precondition.
I am in Canada and expect it could be a challenge to find a local capable of doing the work.
Discussion starter · #278 ·
PM on the way...
