Anyone installed one of these in a 2004 Treg with a Delta radio?
Thx
Thx
Everyone is talking about a larger screen at 7", but any idea of the screen manufacturer? I believe the original aftermarket unit posted here referenced a Panasonic screen. In my opinion, this should be an important consideration.
Here are some pictures after I modify the unit: add a fan, change the amplifier IC TDA7388 to PLA007A(or TDA7580),add a USB port on the rear of unit. And when I check the voltage of the antenna input port, I made a short, burn the fuse......Today I just check the USB port, it only support 8G usb flash dirves. I buy the 16G usb flash drives, but it doesn't work, so I separate it to 2 partition (8G each), and hide one partition, now it work like SD card. But in menu, no USB option to choice, you can use " SRC " to pick after RADIO option.
I don't want a Szenco unit. It's speaks cheap to me. Past the line that I don't like to cross. But then again, I have no basis on what I just said either. It's just a hunch of mine. I'd like to hear/read a review or two on this product before I proceed on it. Seeing that there are none, I'm a little hesitant to proceed. The Maisun on the other hand has been tried and tested by two members here already. The only shortcomings of the Maisun, are the lack of Iphone 3GS compatibility(NOT to be confused with the 3G!), and no SDHC, only SD. So I guess I'll have to keep the "older" 3G version, for as many years as I can, before I upgrade the head unit againFolks, an update on this. Szenco replied and their pricing is identical to that of Maisun, the advantage with Szenco is that they accept paypal or credit card, and Maisun only accepts wire transfer or western union. I would personally prefer to send $5000 across the world with some sort of sense of security so I would lean towards buying the Szenco units only because of payment methods they accept.
Is there any group preference one way or the other?
This is interesting...Does anyone know the amplifier specs on the OEM RNS-510, since we are supposedly trying to buy RNS-510 REPLICAS here?This unit has not the fan, so I add a fan, get the power from the P-CON (blue wire). TDA7388 only 4 x 35 W, but TDA7850 - 4 x 50 W. (Sorry in the previous post, I wrote the PLA007A and TDA7580, it is wrong, it should be PAL007A and TDA7850)
+1Did your original Audio setup not have external amps? I believe the level II system did have external amps? Which is what I have. Does anyone know if this aftermarket system will work with OEM external amps?
Guys, I'm going to wait out a bit on this. Here's why. It is the one and only thing that is eating me up concerning the Maisun unit, which I still prefer over all else. Here is the email I sent to them, and the answer they sent me back to me within literally 45 minutes! That sais something good concerning their customer support.
Observation from me having fitted one of these last week - there is a massive heatsink on the rear. Why is a fan required? A fan is going to suck in crap and clog the fan (eventually). If it ain't broke, don't fix it. Just a thought.Can you elaborate on the changing of the fan and amp? Was the original not adequate? If not, what troubles did you experience?
I assumed from other posts, that the factory external amps would still be used. I have the Level II system, from what I recall...which I believe has higher watt output. Can anyone elaborate? I have a 2007 NAV II.
I don't have $500 of maybe works money kicking around.. thanks though. Can't wait to see the results of your installs.The '04s that came with CD nav is up in the air...I am taking the risk on my '04 and will report how/if it integrates. That said I was only intending on doing the group buy once...you may also want to take the risk and buy, if it doesn't work list it on ebay or here for another member
They are probably talking about plugging the iPhone into the radio to get the music/audio from the phone as well as charging the phone. Even if it isn't fully compatible, it should still transfer audio via cable but it won't charge.Here's my take on the 3G(S) issue. From what I can tell, nothing about the 3GS should differ with respect to the bluetooth functionality...as it relates to hardware (chipsets) in the NAV unit. My 3GS is backwards compatible with every bluetooth I've ever owned, from Moto to Jabra to Nextlink. Regardless of Bluetooth Rev level.
Basically, this is a firmware issue that they are dealing with. If this unit is working with everything else out there, they are merely working on code. Don't expect a completely revamped board to solve this issue.
While still a limited risk in buying the current model, I would bet on a firmware update to solve this!
