Apologies if the answer is already here on the forum somewhere - I did search but could not find a definitive answer...
I have a 2011 7P Treg V8 TDi. It has the Xenon/HID headlights which seem bright enough when in the driveway and around town, but get out on the open road (and particularly back country roads) and the high beams are complete rubbish, to the point that they barely light up the road ahead (or markers/signs etc) any better than the low beams.
I'd like to install a bar to mount some auxiliary LED lamps - currently considering this bar which conveniently bolts on to the factory tow eye attachment points. It works out to around NZ$800 delivered so not exactly cheap.
I'd like to get a decent pair (or even 2 pairs) of LED aux lights - probably some Stedi Type X Evos - they seem to be everywhere here in NZ now. But I'm getting conflicting opinions on how they need to be wired in order to use them only on high beam as our laws require - I understand that there is no pigtail adapter plug available/possible for the 7P which is a real pain. But there's argument online over whether you can just tap into a high beam wire, or whether you need a special CANBUS unit to be installed to trigger the aux lights on high beam setting. Can anyone here who has installed aux lights on a 7P give me a definitive answer please?
Or am I over-complicating it? Should I just buy replacement headlamp bulbs, such as the Stedi D3S units? I'm aware there's no separate lamp for high beam on the 7P, and that the high beam switch merely moves a lampshade (for want of a better term) within the headlamp assembly.
Thanks in advance for your help!
For the removal of doubt (and in case I've misidentified what lights I have), here is an example of what my lights look like - with the individual DRL bulbs rather than the strip on the 2015+ models:
