Wiring diagram camera connector
9.8K views 22 replies 4 participants last post by  DrGER
Hi, I bought a Touareg 7l6 that had a Chinese radio. I bought the RNS510 and plugged it in but I would also like to plug in the original reversing camera. I have the connector disassembled (probably someone was trying to get a video for that Chinese radio). Does anyone have a schematic of where which pin should be? Respectively where which cable?
Let's back it up a little here.
Do you know how to read wiring diagrams, or did you just ask for them without being able to read them?
Which connector are you attempting to "rebuild"?
The 26 pin?
Look at 37/6 for example.... it shows you some of this connector
I'm unclear as to what you're trying to do or figure out, as all the relative information should be there.
I feel like you're not up to speed on this reversing system at all.
The actual camera that's on your trunk lid doesn't connect directly to the back of the RNS510.
There are other modules in the system.
I was very specific when I asked which connector you're working on, but you failed to answer in a specific manner. I still believe that you are talking about the 26pin, and if that's the case, you should have all information to figure it out, or to ask very specific question if further information is required.
Good luck.
Good luck.
hi, quite an older thread but i see you might have answers :D.. i have one chinch from my reversing camera and i would like to make adapter from 26 pin connector.. i have + and - on chinch but do not know where to connect them on the 26pin.. I look forward for your reply! Thanks.
Short answer is: NO. Either you use a component-to-composite video converter, or you use a rear lid handle that has a component video camera, e.g., with the blue FAKRA HSD connector:
That is, unless your car also has a backup camera module (J772). --g
