Vw Touareg Water to air intercooler install
19K views 58 replies 12 participants last post by  yrktreg
Gooday not sure what I got my self into but I ordered the kit and started haha
my stock intercoolers and piping available to buy!
239774
Updated: some how can see light end of tunnel permanent locations of rad and core, sacrificed few of plastic parts that direct airflow behind bumper but ahwell, as for pump im going with genuine vw pump that is already hard wired into the fuel/water cooler with piggy back into a second pump that will flow water for fuel cooling system that am currently trying to position
240429
So far most expensive parts have been T Bolt Clamps which i could of got a whole pack of 20 of ebay rather then retail price of 14 bucks a pop
If you like this idea of getting rid of side mounted intercoolers I could give you dimensions of the 3 part custom pipes and you could even place a air to air intercooler 600x400x75 or something but you would have to consider the snorkel option which hopefully I will have a solution to also more to come..
240432
240572
Pipes nice and shiny
Today installed and tested fuel cooler pump plug and found no power perhaps it was never working or comes on at a specific temperature so back to the drawing board
240629
New fuel cooler and rest all plumbed
Just need ignition power source in engine bay, for fan i will be using a single motorcycle fan on a davies Craig thermo switch that comes on at 40degrees, excited to give it a test run it this weekend with some logs
Its justified that side mounted intercoolers does not sit well going through mud puddles, I've pulled out massive branches out of them with near miss to actual core though offcourse i watch obd whilst driving for pure pleasure, sort of cable tied things to where they should be and it makes the engine bay easier to work on now
For few 100 bucks why not! ill try my best to list what's required etc..
I think it is hard to say. Generally you are on boost for short periods of time. Water has a large heat capacity, so it depends on the duty cycle or how long you are on boost, and how long you have to cool the water down before the next boost event. You could calculate it all out if you know the temperatures and times. just eyeballing the size of the radiator compared to the size of the intercoolers it looks to me that the heat removal capacity is lower for steady state than the original air to air intercooler. But it may be okay depending on the duty cycle. Some racers use a bucket of ice water rather than an radiator because it work with their short duty cycle.
if you are want charge cooling for going over a mountain pass, then i agree it looks too small. If you just want to just get rid of the stupid wheel well mounted intercoolers for off road use, it may be fine. My gut feeling is the surface area of the water radiator should be equal to or larger than the air-air intercoolers you are replacing......but then again, you could use forced fan cooling. Basically you need to do some fin counting, measuring and calculating because who the hell knows.
Using the diesel fuel cooling system is the same thought I had on how to add water IC's. I was thinking of replacing the side mount IC's with smaller water IC's in the same location and keep all the air plumbing basically the same. That would allow using non turbo wheel well liners that will give you an extra room for bigger tires, plus eliminate the vulnerable OE coolers. Are you going to add the additional radiator in series with the existing fuel cooling radiator?
Intercooler all done, difference in power and efficiency is night and day, snorkel will have to wait after long weekend
Temps don't go passed mid 50s when flooring it and cruising hovers around 9 degrees more then ambient temp give or take, was tested today at 30 degree ambient also wired up the water up temporarily to fog lights, so if my fog lights are on you know dam right I'm running cool :cool::cool:
I'm not hating on your setup, but I'm doubting your reported results.... there's either more to it, or the assumed constants are not the same between your reported values.
Air to Water ICs do have their place and purpose, but it's typically in racing applications (where you can use ice water, etc) or in very confined street setups.
The surface area of your A/W core isn't larger than the combined surface area A/A SMICs. They are both using the same core thickness too. Sure, you've shortened the charge pipes, and I can understand that you may have picked up response as a result, and that you may be feeling an improvement as previously reported.......
But with all other things being constant, I don't see how you are getting 20 deg temp drops, especially when with A/W you need to do the "heat exchange" twice instead of just once. You're also reporting these difference while driving on a beach, so I can only assume that you're not into very high speeds......... What am I missing? Is it simply because your SMICs were all beat up and clogged and the new core is fresh and that much more efficient?
Mate, you're posting your stories in a tech forum....quit with the visuals that don't mean anything. And who's talking about boiling water?
What was the ambient temp and engine load in each of your shots?
What are you showing us?
Which pic is what?
Water is only cool when you add it to the system or after it cools down to ambient before is starts cooling down your charge. After that, you can only cool down the water with the ambient air. In racing applications, you can use ice water from a reservoir, so in those cases, you can cool your change lower than ambient air.....
So now that we've determined at ambient air is your cooling "limit", note the following.
With A/A, the maths say, you only take the hot air and you cool it down with ambient air.... and you get X.
With A/W setup, you take your hot air and cool it down with your ambient water initially, but after that you cool it down with your hot water which you must first turn into cool water with your ambient air.... and you get Y.
Because of the additional two stage heat transfer, X is less than Y if all other things are constant.
This is why I'm asking where are you getting your extra efficiency from? You haven't increased core surface area or thickness. You aren't running a ice water tank like those used in drag racing applications for example.
So you're either telling butt dyno stories, or you've got other variables\changes which you haven't mentioned.
I'm simply trying to understand and gain knowledge.
